topping off fluids Has anyone tried this transfer pump?
   / topping off fluids Has anyone tried this transfer pump? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Manual Transfer Pump | Princess Auto
Similar item listed with Amazon, but I've not seen them at the FLAPS
I'm worried that with a $20 price tag, it will be no better than the piece of "basura" I have now.
I'm looking for a simple, durable tool to pull fluid out of the pail/jug etc. and put it in through a differential fill/level hole with the minimum of fuss, clean up and dripping. Not looking for electric or air or ... orr...
A bucket pump might do, but I've not come across one that would transfer "specialty" fluids from quart containers etc. Something the above referenced tool looks like it will do.
PS, MUST WORK IN -10F WINTER TEMPERATURES ! plastic has no place here ;-)
   / topping off fluids Has anyone tried this transfer pump? #2
I bought one like that, and used it once. It worked but was very messy. It does work better to push fluids in than to pull fluids out. After using that one, I spent the money and bought a fluid extraction setup and have never looked back. You pump up a vacuum in a plastic tank (there are many brands now a days) and you stick the stinger into any small hole and remove any liquid. The "Suck-Up" that I use works great and had never let me down in 20 years. You can also use a cheap weed sprayer (removed the nozzle) and use it to pressure feed fluids into tight spaces.
DEWFPO
I use the 6 quart garden sprayer for larger fluid fills. But for a half pint to top off a diff, it seems like too much trouble to clean out the rig after.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50323)
2015 Big Tex 70PI...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Kubota RTV1100 Utility Cart (RUNS) (A50774)
Kubota RTV1100...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
