Top off or not?
/ Top off or not? #1
Gryphyn454
Florida
2019 Rural King RK24
I removed the backhoe today on my RK 24 and saw that the transhyd is at the bottom of the sight glass.. Should I top it off if I do what happens when all the fluid stored in the backhoe is added back to the tractor hydraulic system?
Thanks for the help!
/ Top off or not? #2
Top it off. Nothing will happen when you add the backhoe back on... however;
Did you release the hydraulic pressure in the backhoe's lines before looking at the hydraulic tank level?
/ Top off or not?
Thanks... No I released pressure through the FEL joystick. Assumed I would have maintain pressure in the BH until was freestanding and blocked up
/ Top off or not? #4
Always relieve the pressure in all BH lines before disconnecting. I didn't do that once and learned pretty quickly when I had to use wrenches and loosen fittings to relieve the pressure because I couldn't reconnect the lines otherwise.
/ Top off or not?
Sounds like I'll have to do the same when the time comes to put it back on
