Top N Tilt on 4000TEN
   / Top N Tilt on 4000TEN #11
Tim...
I'm sorry....but I have to plead ignorance here regarding the question you ask. /forums/images/graemlins/confused.gif I don't have the optional draft sensing controls and so I've never thought on this issue. However, what you suggest about shutting off the draft sensing controls before operating the TnT is plausable. It may be possible to wire both systems so both operate compatibly but this would require even more skill on the part of the installer in correctly wiring the controls so all works as desired. This, I would think, would be the major challenge.....wiring up everything correctly.
Another point about my system....this was the first 5 SCV install that my JD technician did on a compact tractor. He mentioned to me upon delivery that it was indeed a challenge. My technician was very good with solid tech training but he did say it was a bit problematic installing all components of the TnT and making sure everything was wired correctly with hoses running where they should be so they wouldn't interfere with the physical operation of the tractor. I understand what he meant when he told me this. When operating the 3PH with a couple attachments, I've noticed that if I'm not careful I could potentially pinch the hydraulic hoses to the point of damaging them with the way the top link extends and retracts. I've also had to run the tractor on a few occasions around low hanging tree canopies with my foldable ROPs in the down position. Here, I've noticed the top cylinder could potentially jam up against the top of the ROPs that's now folded down so close to where the top link is located. Potential damage could be bending the extended top link cylinder and denting the ROPs if the ROPs is folded down to its maximum extent. This top hydraulic cylinder has a tremendous amount of power. I've already bent and twisted my top cylinder restraining strap a couple times to the point it looked like a pretzel. I had to get a replacement. I now remove this strap altogether before I operate the 3PH.
So, it's indeed an understatement about the physical/fitting conflict. There's a lot bunched together around this 3PH. Adding anything else may be even more of a challenge. I believe the TnT is well worth the investment for anyone who is operating a number of attachments and wants maximum flexibility that'll produce optimal performance of their equipment. But, I also believe that for it to work properly one should make sure they have the sufficient skills to do a proper TnT install or they should have an experienced technician who likewise has similar skills.
Hope this answers your query somewhat.
...Bob
   / Top N Tilt on 4000TEN #12
<font color="green"> There's a lot bunched together around this 3PH </font>
Bob - I surely can believe that! /forums/images/graemlins/tongue.gif
Is the top-n-tilt set up to be removable? Even in the pic you posted - it's tough to see if the hoses from the hitch cylinders are running to quick-connects or not. If they are, then I could assume that a 4000-TEN ordered with the maxed 5 SCV's, and one set up for T-n-T (but with the regular links installed) would look the same?
So, it appears that I won't save much, and it wouldn't be nearly as "slick" to try and piece that together...
Thanks Bob, This doesn't let you off the hook, Stan. PICTURES!
Thanks, all!
   / Top N Tilt on 4000TEN #14
<font color="blue">"...Is the top-n-tilt set up to be removable?..."</font>
Tim...
Yes....the TnT's hydraulic couplings are quick connects. If something ever happens to the hydraulics when I'm in the field and I don't have time to immediately have it repaired I can quickly disconnect everything witnin a minute and hook up my standard top link and right adjustable lift link that I still have since they came as part of the standard tractor package.
..Bob
Yellow Posts (A55973)
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
