Rotary Cutter top link
   / top link #11
once the lower arms are connected lift them up a little so that it lifts the mower closer for the toplink. Kind of hard to explain why but it works for an inch or 3 closer for my attachement on my tractor
I think you hit the nail on the head. If I leave the mower sitting level (wheel on the ground and front blocked up) I have no problems connecting. If either end is much higher than the other the top link is too short.
My top link is set at 29 1/4 inches overall length for the mower to work well on my tractor (L3400 w RCR 1860 Land Pride cutter) Also, the top link is in the lowest hole on the tractor.
With it set up to mow about 6" height, if the cutter is sitting level behind the tractor, there's a slight sag in the top linkage, as it recommends in the manual.
Check the manual for the tractor AND the cutter for set-up procedure, it helped me quite a bit. The cutter manual should be available online of you don't have one. Even if yours isn't listed, almost any cutter manual will do the trick, there isn't a lot of difference setup-wise anyway.
Sean
International 720 6-Bottom Plow (A52128)
International 720...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
66in Light Material Bucket Skid Steer Connection (A52128)
66in Light...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2020 KUBOTA RTV...
