Rotary Cutter top link
   / top link #1
brix
I am having trouble with a top link adjustment. When I am hooking up my mower, it seems that the top link is got to be extended all the way out. I've got the arms all the way in. Can't figure it out, what am I doing wrong The link is 32" extended, should be long enough. The tractor is a Kubota mx5000.
Brix
   / top link #3
What is the mower model? Can you provide us with a pic?
   / top link #4
A picture would definitely help. Almost sounds like your missing the piece that goes on the mower that allows the mower to pivot up and down. Mine is a U shaped piece of steel some others have mentioned a chain setup.
Good luck.
   / top link #5
Does it have a "U" shaped bracket like this one below??? Also, I normally don't attach the top link when I'm mowing The tail wheel stays on the ground the whole time and just lift the the lower arms when I need to get over a rock.
   / top link
It's a woods mower, it has the pivoting u-shaped swivel. Don't currently have it hooked up. Next time I have it on I'll snap a pic.
thanks, Brix
   / top link #7
once the lower arms are connected lift them up a little so that it lifts the mower closer for the toplink. Kind of hard to explain why but it works for an inch or 3 closer for my attachement on my tractor
   / top link #8
I have seen implements that required a long barrel toplink. This may be one of them. Ken Sweet
   / top link #9
I agree with Ken, get another top-link if you need to for the correct angle. Even with a hydraulic top-link, I have a regular one a little longer.
   / top link #10
The standard toplinks have approx a 16 inch barrel and the long barrel is 20 inches. Ken Sweet
Land Honor Quick Attach 72" Skid Steer Rock Bucket (A50515)
Land Honor Quick...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
