Top Link...what is it for?
/ Top Link...what is it for? #1
dty
New Jersey
Kubota 7610
I am new to this tractor stuff. I have a 7610 and just bought a rotary cutter. Can someone please explain to me what the top link is for and how is the proper way to use it? /forums/images/graemlins/confused.gif
The Kubota manual breezes over the subject and the Rotary Cutter manual doesn't mention it at all.
Thanks in advance /forums/images/graemlins/smile.gif
/ Top Link...what is it for? #2
It is used to set the angle that the implement needs to function. On a rotary cutter it is used to set the cutter at the proper angle to the ground when mowing.
oops... /forums/images/graemlins/blush.gif maybe that was a dumb question.
/ Top Link...what is it for? #4
Don't feel bad. I actually asked what a "CUT" stands for.
Sheese, now THAT was a dumb question.
-Terry
/ Top Link...what is it for? #5
I guess they figure a buyer has some experience or usage is intuitive.
Your tractor manual should discuss the 3 Point Hitch to a degree. The two lower links (draft links) actually do the lifting part. The upper link (top link) helps stabilize the implement your are using when hooked to the upper connection of the implement you are using.
For example, your rotary cutter should have two pins approximately 3/4" in diameter and about 4" long. The are horizontal. Your lower links (with the ball eye bushings) connect here.
There should be an upper bracket that probably swings. The upper (top) link connects here. For use, you thread out the link so that bracket on the cutter can follow the ground contours. For transport, you tighten (shorten) the upper link as much as possible...by hand. There is a jam nut on the threads of the upper link closest to the tractor end. I just run it up by hand, but I don't transport my implements too far. Once tightened, you can raise your cutter, but don't raise it high enough to have the PTO shaft riding on the front end of the cutter.
Also, by tightening or loosening the upper link, you can raise or lower the front end of the implement somewhat. For a rear blade, this makes for a more or lesser aggressive "bite" in the soil.
To hook up the cutter, have the tractor engine off with the key in your pocket (in YOUR pocket!). Hook the lower links to the pins on the cutter and install the lynch pins in the holes (on the cutter pins) outboard the tractor's lower links.
Then, hook up the PTO shaft. If you look at the tractor's PTO, you'll see a groove machined circumferentially on the PTO. The implement PTO shaft will have a mechanism that locks in that groove. The PTO shaft will have a spring loaded button or ring on the tractor end "U" joint. Depress that button (or rotate the ring) and push the "U" joint on the tractor's PTO. Once the splines are lined up, let go the button (or ring) and push toward the tractor until you here the shaft's locking mechanism lock into place. Pull back on the shaft to ensure it's locked in place.
Rotary cutters don't have front wheels, so I suggest you have some kind of lever handy to jack it around a bit to get everything lined up.
Now, this may sound complicated, but with a few tries it'll take you less time to rig up an implement then it did for you to read this.
Good luck!
now that was an answer! Thanks Roy
/ Top Link...what is it for? #7
Roy, I'm glad you gave such a detailed tutorial about the pto attachment and the way it locks in the groove. The hookup is critical for safety. We've all heard the stories about pto's.
Five points for Roy /forums/images/graemlins/laugh.gif
/ Top Link...what is it for? #8
</font><font color="blue" class="small">( Don't feel bad. I actually asked what a "CUT" stands for.
-Terry )</font>
<font color="red">C</font>ute <font color="red">U</font>gly <font color="red">T</font>ractor.......??????? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Top Link...what is it for? #9
David,
I too have a 7610 and am looking at rotary cutters. What kind of cutter and what size?
Donald B.
/ Top Link...what is it for? #10
I asked MChalkey (an "ex" TBN fella so full of wisdom and other saucy things, it's too bad we are not blessed with much of his spew anymore) the same thing. I also spent a period of time figuring what FEL, MMM and PHD meant. I thought a FEL was something folks back East must use that we don't use out here, you know for dragging logs or cutting trees. MMM was some kind of new candy and PHD was the level of intelligence needed to understand half the crap people were talking about. Now top link, I knew lots about that. I even corrected O'l Bird on the TnT acronym once. Folks were calling it Tip N Tilt. I quickly nipped that in the bud. TnT is not dynamite, it's Top and Tilt. Now if you have a hydraulic Top Link, thats DYNAMITE! /forums/images/graemlins/cool.gif Thats <font color="blue"> Mr RaT </font> to YOU!
Mathteacher...I picked up a King Kutter 48". Paid $550 here in NJ. TSC had them for $500, but the closet store to me is 75 miles away in PA.
We are building a new house and one of the acres is a field that has gotten way out of control. I am hoping to turn the field into lawn in a year or two, at which time I'll use the MMM to mow and probably sell the rotary.
I used it last weekend and it worked well...even though I didn't have the top link adjusted properly /forums/images/graemlins/tongue.gif Cut through some thick stuff 4+ feet high.
/ Top Link...what is it for? #12
</font><font color="blue" class="small">( Folks were calling it Tip N Tilt. )</font>
"Folks"? Or just O'l Bird? /forums/images/graemlins/laugh.gif You caught me that time, sure 'nuff. /forums/images/graemlins/laugh.gif
/ Top Link...what is it for? #13
You may not even want to use the top link with the rotary cutter, since it has a wheel on the back. I do this sometimes when I need a lot of float, in a hilly area or when I am cutting ditches. The only disadvantage I have seen is you cannot lift the entire cutter off the ground, but that's OK because it has a wheel on the back. /forums/images/graemlins/grin.gif
Chris
/ Top Link...what is it for? #14
Not want to use a top link? See the thread about "how much slack for a rotary cutter?" and see the consequences of 'not sufficient top link' as the deck may contact the PTO shaft. Just a thought.
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
Teakwood Rocking Horse (A65583)
Teakwood Rocking...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2017 EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
2017 EZ-GO SHUTTLE...
