Top link too big for my B7500?
   / Top link too big for my B7500? #1
BrokeSolid
Falling Waters, WV
2007 Mahindra 2615HST, 2009 Grasshopper 928D
i just bought a used rear blade for my tractor yesterday and wanted to move it after i pulled it from the bed of my truck. when i backed up to it i then realized i didn't have a top link. don't know how i missed it, but i did. so off to tractor supply to get a stage 1 top link and pins. 30 bucks later i came back to hook it up and it's about an 1/8 too wide for the tractor? i just pulled out the grinder and hit both sides a little bit, but is this something that's typical for a compact? are the stage 1 links not quite whats on my tractor? or is that what you get when you buy some generac parts from a common distributor.
i guess i shouldn't complain cause it's working now but, just curious.
Also what a deal i got on the blade. it is a taylor pittsburgh 72" slider blade, rusty, but looked unused for $70. i felt pretty good about that deal.
Brent
   / Top link too big for my B7500? #3
Due to adding QA's (Pat's) to 3ph I had to get another longer top link. Mine was a hair to big at the connection so the handled nudger came out and whacked the connector at the top a time or two or three to encourage it to be a tad wider. It accepted the encouragement and the top link then fit on that tractor. Did chip the orange paint a bit so if chipped paint bothers you, then grind top link arm or get some touch up paint.
Great! sounds like i'm not the only one then. after some quick grinding it was fixed, just wanted to make sure this was typical!
Peterbilt 377 Semi-Truck (A52128)
Peterbilt 377...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
