Top Link on Implement
   / Top Link on Implement #1
drewrowland
2021 Kioti DK50
Hi,
New to the tractor world and just bought an old used ford blade. The bottom links fit perfect in my Cat 1 hookup. However, the top link diameter on the implement seems to be larger and so my top link pin actually just slides ride through.
Is there a bushing I’m looking for to reduce the implement hole sizes or can I just get a different pin that does not slide through, but then is there an issue with the slop in the cat 1 pin size and the diameter of the holes on the implement?
hope this all makes sense and thanks so much!
   / Top Link on Implement #2
Maybe some big washers on each side?
   / Top Link on Implement #3
You can purchase a bushing to increase the diameter of your Category 1 Top Link pin to Category 2 diameter at Tractor Supply Store, Rural King or other farm oriented retailers. Probably every tractor vender too.
   / Top Link on Implement #4
Sounds like you have a category 2 top link. And yes there are bushings to change cat 2 to category 1 pins.
So the top link is definitely a cat 1, but it seems like the holes of the implement are a cat 2 or maybe some type of homemade fix.
   / Top Link on Implement #6
My Landpride blade has cat 1 lower pins but the top link pin is 1in dia instead of the std. 3/4, this was for a quick hitch. Landpride sells flanged bushing to reduce the top link pin holes down to 3/4, maybe yours is the same.
Sent from my SM-G715U1 using TractorByNet mobile app
   / Top Link on Implement #7
These are on the shelf at tractor supply
   / Top Link on Implement #8
I haven't seen any flange bushings there, just the standard spacers to increase pin diameters. The ones for mine are a split type and press in so they won't fall out when the pin is removed.
Yeah, a flanged bushing is what I was thinking I would probably need. I’ll go check TSC tomorrow. I guess I should probably also measure the actual diameter of the holes too.
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
71065 (A49346)
71065 (A49346)
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A51242)
2014 JOHN DEERE...
