Top link mounting hole?
   / Top link mounting hole? #11
Aren't there a few (and thankfully) rare cases of the top link bracket being ripped from the tractor? I'm guessing that abuse most likely caused this but using the wrong hole (no pun intended) create a situation where the tractor could be damaged.
   / Top link mounting hole? #12
If your top link is set so that it angles to severely to the lift arms it is possible to have a geometry that will not rotate and the top link can be ripped out or bent just by raising the impliment. Like you say rare but possible on some equipment combos.
   / Top link mounting hole? #13
I normally use the middle hole. It gives me the most parralel lift. I gotta have the ballast box level, or the neighbors will talk.
   / Top link mounting hole? #14
There are two answers to that question:
1: trust me it does. or try it yourself. with the top link jack screw all the way in or your hydraulic link all the way in. put it in the bottom hole and hook on a rotary cutter or some other long implement where it will be the most noticeable and measure the tailwheel height then put it in the top hole and measure it. The bottom hole will raise the tailwheel higher.
2: It is geometry. The geometry is a parallelogram. the toplink is the top of the parallelogram, the lower links the bottom, the left side of the parallelogram is the fixed height of the measurement of the pins and the top link hole on the implement. the dynamic measurement of the right side of the parallelogram is the height measurement of the pins where the tractor end of the lower link arms fasten on to the tractor and the holes where the top link will fasten to the tractor. Your choice of top, middle or lower hole. If you choose the lower hole the right side of the parallelogram will be shorter and as you raise the lower link arms they rotate around the their fixed pins on the tractor, and since the top link jack screw is turned all the way in, the left side of the parallelogram will tilt more toward the tractor which will raise the tail wheel higher off of the ground. If you don't understand all of this, see answer 1 above:)
James K0UA
Got it! :D
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
