3-Point Hitch Top link length - Hoping someone can help me out
   / Top link length - Hoping someone can help me out #1
kspring61
Now Western TN
Kioti DK40SE HST Ford 8N
I am getting ready to order a hydraulic top link from fitritehydraulics. Problem is my tractor is in TN and I am in PA and I need to know the length of the top link.
2014 DK40SE HST, anyone have one that could measure the top link min-max for me?
21 1/4"- 31 1/4" is what Brian @ Fitrite thinks it should be, but would like to be sure, I can order and change the length before it is built but not sure when I will get down there again to measure.
Thanks!
   / Top link length - Hoping someone can help me out #2
Thanks!
Brian has made the same link for me so I'm sure he knows what length to make.
Actually he said it depended on the year of tractor
His quote to me in an email
"A cat 1 top link with a working length of 21 1/4"- 31 1/4" with the
hydraulic ports on the side. $275
The working length will vary depending on what year your tractor was built.
Kioti switched sizes in there some where.
We can change this at pretty much anytime before it gets built without any additional charges."
So there is some question on length based on year that is why I included my year on the tractor.
   / Top link length - Hoping someone can help me out #4
My machine is a 2011 K code what is yours? You need to know your serial # Wrong mine is a 2010.
Hmmmm......looking at the paper work it says the SN is MT6500152, does that sound like the right format?
   / Top link length - Hoping someone can help me out #6
Yes your year code is M that means its a 2012, sorry my code year was wrong mine is a 2010 not 2011. I was told they did not use the letter I.
   / Top link length - Hoping someone can help me out #7
I believe that the change was made some where in 2013-2014. With it being an older model, let's go with 20 1/4"- 29 1/4". If that is not what works well for you, I will exchange it, no charge to you. You are not using Pats QH are you? That changes things big time.
Let me know
   / Top link length - Hoping someone can help me out #8
Let me know
If his is truly a code M it is a 2012 model Brian. His should be the same as mine .
Yes, sorry I typed 2014 in the OP, but meant 2013. Is the code for the build year or model year? Like 2016 cars are actaully built in 2015
More interested in this given the dealer sold it to me as a 2013.
Let me know
OK I am comfortble enought now just to go with that, will place the order tomorrow
Thanks Murph and Brian!!!
   / Top link length - Hoping someone can help me out #10
As far as parts, you have to go by the build year, your case "M" - 2012, and sometimes parts may change within that year. So the full serial number is sometimes required.
Tractors are different than cars. The year that they are built in is what it is. I believe your dealer got you on that one. I had bought a CK30hst 2004 build year tractor in April 2005. It was brand new but still a 2004.
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
202473 (A54757)
202473 (A54757)
LOT: (10) Wheel Loader Bucket Teeth (A59076)
LOT: (10) Wheel...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
