Top Link Jam Nut
   / Top Link Jam Nut #11
On my JD the top link has little levers sticking out to turn it. I often get the jamb nut where I want it and then use the levers on the top link to tighten it up to the jamb nut. It seems to hold.
   / Top Link Jam Nut #12
I give a small tug with a wrench on the jam nut. My problem is when removing the implement I sometimes forget to loosen the jam nut BEFORE I pull the pin at the implement connection. If I do that I have problem loosening the jam nut when I mount the next implement. Just a maddening pain.
gg
   / Top Link Jam Nut #13
My Deere 855 came with 3" studs welded to each side of the nut. No tools needed.
   / Top Link Jam Nut #14
I always snug it up with a wrench...it's a pain in the neck; but it stays where I put it.
   / Top Link Jam Nut #15
My experience is it needs to be wrench tightened.
   / Top Link Jam Nut #16
I have a Kubota M7060. I tighten it with a wrench and it will still loosen after several hours with the 10 foot flail. Drives me crazy.
I wonder if two nuts would be a cheap better system. Like the way two nuts on a steel fishing rod reel seat rarely loosen. Only one nut on a steel reel seat is useless.
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2121 (A51244)
2121 (A51244)
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
