Top link installed
/ Top link installed #1
bwmarine
western michigan
cub cadet 7235
Pretty easy install, waiting for the ram to get back in stock was rhe hard part lol. I am happy with a clean installation! 5460 tractor by the way...
/ Top link installed #2
It look a lot like mine. My dealer said has having trouble keeping them on shelf.
The wire tied to the cylinder is for giving power to trailers to release brakes for back up. We move a lot of trailers and many of them the brakes lock up in reverse if you don't have power to release them
/ Top link installed #5
Only issue I see is, you only have 2 sets of remotes so one is now taken. On mine, I have 4 sets and I can actually use 3 at one time depending on how much hydraulically intensive the implement is I'm hooked to.
I had room for one more, but what I use the tractor for 2 is fine. I don't see using more than 2 in the future... if things change I can always use a relay switching system to add more remotes.
/ Top link installed #7
I don’t have any other impliments that use these valves until winter snow plow. At that time I won’t need the hydraulic top link . My hydraulic tank is on fixed top link. My equip is not for farming or ranching.
/ Top link installed #8
My hydraulic top link is from Fit Rite. Got is seven years ago. It's become a permanent fixture. I even use it to set my Wallenstein chipper down - flat on the ground. Particularly useful with my - rear blade, LPGS, ROBB, disk harrow and mold board plow.
/ Top link installed #9
Top link has been there, transferred from old tractor. Put the tilt on yesterday. It sure makes a difference with the box blade.
/ Top link installed #10
When I worked for a Kubota dealer, I installed quite a few T-N-T kits. We would use Gearmore kits out of California. They use a fender mounted 2 or 3 spool valve. I would usually install the 3 spool so that the customer had a 3rd spool available for another function if needed. Cost wasn't that much. Also installed quick couplers on all 3 functions so that the TPH could be removed if necessary. IE installing a backhoe. Just checked and you can get Kubota 2 spool factory style for the B series and 3 spool for the L series. Just remember, the cylinders would have to be ordered separately. I have also installed these. I think if I was going with a new unit, I would use the Kubota style as you won't have the valve and hoses on top of the fender. Just my thoughts.
Got the funky cat 1/2 ram from the agristore, thinking 275.00 and the lines from tractor supply and thinking 45ish dollars. Not too many suppliers with the cat 1/2 for the larger L series.
Have a grader blade, box blade, rake, hitch, and snowblower to use and the hydraulic top link will save a lot of hassel in adjustments...
/ Top link installed #12
I’m still thinking about the tilt unit for my rear blade. Would save a lot of time. My dealer was all out when I got the top link. I may wait until the supply line right itself before getting the other. Tired of trying to track down parts. Getting old.
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2022 EZ-GO ELITE...
Sky Jack SJ8831RT 4x4 Rough Terrain Scissor Lift (A61572)
Sky Jack SJ8831RT...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
OXBO CP100 - 1R SWEET CORN HARVESTER (A63291)
OXBO CP100 - 1R...
