3-Point Hitch top link hydraulics
   / top link hydraulics #31
YES....Thanks, this is what i'm looking for, but I do not unstand the bypass switch (some sort of a cartridge shuttle valve?). If the fel valve is power beyond..you should be able to run the 3pt at the same time (provided the volume is there).
On my tractor, there is a hydraulic block - don't know exactly the right buzzword - that sits near the hydro filter. There is a switch/valve that turns with a screwdriver blade. In one direction it powers the 3pt hitch internally, but no accessories are activated. In the other position, pressure is diverted to a fitting, and return pressure must be applied to another fitting (the switch shorts these two nodes). The pressurized fitting powers the accessory or accessories, and PB from the last accessory comes back to power the 3pt hitch.
JayC
   / top link hydraulics #32
Kenny...chill, I never said I was an expert. I already admitted my mistake on the hp tee. what you are defining as open center is the same as I described in a previous post as open work ports. If I was the hydro guru I would not be asking questions. Also the oil still flow thru the outlet in the neutral position on a closed center valve just the spool closes off the work ports.
Terry, I came off a little rough yesterday...I had a bad day and you where in the wrong place at the wrong time, sorry.
Now, you are still incorrect with that statement you just made.
Having the work ports closed (blocked) when the valve is in nuetral is defined as a "Tandem Center" valve, NOT Closed Center. This is the confusion that you started, and I am just trying to clear it up. I understand what you are saying-But I want to keep the terminology correct so as not to confuse others reading this. I you ordered a CC valve from the Surplus Center-you would fing out very quickly that is would not work.
The Open Center valve that you are describing (where the work ports are open to the tank when the valve is in nuetral) is more commonly called a Motor Spool valve.
   / top link hydraulics #34
JayC
This does not exist on the smaller series 'bota's.
Cool Ken lets start over..I'll post some schematics (if i can figure out how)..I work with curtiss wright and bucher valve manufactures. This is the terminology we've always used. The "closed center" valve and open center valve as I know it is as we were discussing is closed or open work ports with the spool in the neutral position. oil still flows thru to the outlet port. The closed center does not mean a "dead end" for the flow when the valve is in neutral. We build stacks combining both of these to lock hydraulic motors (closed center)and run our cylinders which are mainly self locking (double internal po checks), so we use an open center. But on the cheaper cylinders (mainly horizontal application) we will just use a closed center valve. Anyways. I'll try to stick to the familar terminology. Sorry for the confusion. All I want to do is add a (3) to the rear of my kubota. This should be simple if I could figure out the kubota hydro circuit(s)
lets try this, as you can there are what I refer to as open and closed centwer valves in the same stack
Found it.....Sorry for the confusion. What I was refering to a closed center is what is known as a tandem center outside of my company (and vendors).
TANDEM CENTER VALVES
Tandem center valves when in a neutral position by passes the flow of hydraulic oil to the return line. This is used to hold the cylinder/piston in position with no load on the pumps. When this system is the pump is running constantly to keep a ready supply of hydraulic oil, but as long as the cylinder/piston is not in operation the pump is working under no pressure or load. This system keeps wear and tear on the pump down to a minimum.
OPEN CENTER VALVES
Open center valves are the same as the tandem center, except that in the neutral position all lines are connected back to the reservoir. The primary use of this system is to prevent "shock" loading when the valve is placed in neutral. This takes pressure off the motor. This system is used in situations where the operating device needs to be moved by hand.
   / top link hydraulics #39
Wow, that is confusing. I can see where the conflicting ideas came from.
Hydraulics are confusing enough without having to learn 2 different languages!!
-Jer.
   / top link hydraulics #40
terry2shot, are you still looking into how to tap into your BX hydraulics for you remote valves? I ask because I was looking at the installation manual for a Woods BH6000 backhoe that mounts up to a BX and it shows how they install the power beyond loop for the BH into the existing hydraulic block. It seems you could work off those schematics and just put your valve(s) in the loop with a return to tank hook up. Pretty clear pic's. I saved the pdf so if you are interested, I could post it here for your review.
Now, don't ask me why I was looking at how to plumb in a BH :D
Concrete Bucket Mini Skid Steer Attachment (A55851)
Concrete Bucket...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
CAT 259D (A53317)
CAT 259D (A53317)
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
