Toplink Top link doesn't reach
   / Top link doesn't reach #1
hayden
Veteran Member
VT
Kubota L5740 cab + FEL, KX121, KX080
I tried hooking up my chipper today and discovered that the top link doesn't reach. In looking at the Salsco hitch design I noticed that the top pin sits 3-4" aft of the lower pins where on all my other implements the top pin is directly above the lower pins, or in some cases it's forward of the lower pins.
Anyone run into this issue? Is there sucha thing as a top link extender link? I'm thinking of something that pins to the implement and to the top link and gives 6 inches or so of extra reach.
Any ideas? I did a quick search for the spec for hitches but I could only find them for purchase. The tables I did find only give lower pin spacing and pid dimensions. I haven't found anthing that stipulates the realtive fore-aft positioning of the top pin with respect to the lower pins.
   / Top link doesn't reach #2
Sounds like it may be time for a trip to Tractor Supply and pick yourself up a longer upper arm.
   / Top link doesn't reach #3
I have a couple of top links that are different lengths. Measure to see what size you need for this longer attachment and then go on a witch hunt to find it. It is probably out there, just waiting on you to write the check.
David from jax
   / Top link doesn't reach #4
Cat 1 adjustable toplinks are so cheap, that I have one for each implement. They come in several lengths, I get the one that most closely matches the working length I need for a specific implement, then I simply leave it permanently pinned to that implement. There are a few odd sizes. But the most common Cat 1 come in 13", 16", and 20" sizes. That's the body length. Approximate eye to eye lengths follow;
13" has a working length of roughly 18 to 25 inches
16" has a working length of roughly 21 to 29 inches
20" has a working length of roughly 25 to 33 inches
Try TOP LINKS Available at Agri Supply® where we have something for everyone
//greg//
   / Top link doesn't reach #5
I’ve switched to top links from Tractor Supply because I actually like them better than the Kubota units. As I recall they were in the $25 range.
MarkV
   / Top link doesn't reach #6
Ditto what the others said.. find a larger ( longer ) toplink if the one you have is less than 20" or so..
Soundguy
   / Top link doesn't reach #7
It's too late to edit yesterday's post. But I should have added the Kubota Cat1 numbers for comparison.
Generic 13" has a working length of roughly 18 to 24 inches
Kubota 14.5" has a working length of roughly 19 to 25 inches
Generic 16" has a working length of roughly 21 to 29 inches
Generic 20" has a working length of roughly 25 to 33 inches
There are others, but these seem to be the most common
//greg//
   / Top link doesn't reach #8
My local tractor dealer has three different top links in stock. I have only needed the mid-length top link for all of my impliments, but i guess this problem is why they make more than one length. Pick up a longer top link, they aren't terribly expensive, and you'll have it for future use.
   / Top link doesn't reach #9
Peter, It would seem a short "foldable" section in your top link would be desireable for a chipper - any chance the machine normally has one? The baseplate wants to sit on the ground when it's running - top link is only really needed for transport.
I agree - this is the route I'm going. I bought a hydraulic top link so I wouldn't have to hassle with different links and screw adjustments. I envision a link shapped like a tuning fork where the tail pins to the implement, and the "U" part of the fork forms a spot for the tractor link to pin in. It would be 8" or so long. I've seen something like this on the top link of field mowers so it can swing.
I talked to Joe Rizzo (presumably the brother or son of Sal Rizzo of Salsco (get it, Sal's Co.) They are going to engineer something like this and send it to me. That's great service and the sign of a great company. I told him all the 3PH implements I've seen have the pins directly over/under each other, occationally with the top pin forward of the lower pins, but never with the top pin aft of the lower pins. I'm sure they have their chippers set up this way for a reason, but suggested they consider changing the design. It's probably more complicated that that.
2019 LANDOLL CORPORATION 455B TRAILER (A45333)
2019 LANDOLL...
Miller CP-302 Welder (A44502)
Miller CP-302...
1500 Gal Poly Tank (A44502)
1500 Gal Poly Tank...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
(INOPERABLE) SULLAIR (A45046)
(INOPERABLE)...
2014 MACK CXU613 (A45046)
2014 MACK CXU613...
