Top link Cylinder Noise!
/ Top link Cylinder Noise! #1
Jw5875
NW Pa.
Kubota L3400
Suddenly my top link cylinder makes a "Chattering" noise with hesitation when I lower it with the box blade connected. Checked fluid levels, possibly air in the system???? or ????
Perhaps "Mad Ref" has the answer!!!
jw5875
/ Top link Cylinder Noise! #2
I have a CCM hydraulic top link cylinder and it also chattered part of the time while extending. Also it wouldn't move at times and I would have to disconnect and reconnect the hoses.
Then I added restricted orifice fittings to both lines at the quick connects and that fixed everything and slowed the action down which made it much easer to adjust.
ksmmoto
/ Top link Cylinder Noise! #3
Assuming it has worked flawlessly since day one, and it is now some time since then, and nothing has been connected/disconnected, and it mysteriously started to chatter then I would look at the cylinder rod. A slightly bent or out of line cylinder rod will give the same symptoms. You may not even see the bend, it must be measured.
2016 Ford F-150 4x4 Pickup Truck (A61573)
2016 Ford F-150...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61572)
2023 John Deere...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2015 John Deere 8295R (A64119)
2015 John Deere...
