Top and Tilt for John Deere 790?
   / Top and Tilt for John Deere 790? #1
tomrscott
Newberg, Oregon, USA
JD 790
Has anyone added TNT to their 790? Curious about some questions:
1) What length cylinders did you end up with, and are you satisfied with the length and stroke length? What would be ideal min/max length?
2) How did you connect the plumbing? Did you pick up the power for the TNT valve "P" from the FEL power beyond port "PB" and connect the TNT power beyond "PB" to the rockshaft power "P"? (Replacing a short hard line with banjos on both ends.) Where did you tee in the tank return "T" line?
3) Did you use a JD MP19826 kit? (Their rear auxiliary connection kit.)
4) Whose cylinders and valve did you use? I am leaning toward the CCM kit, but I also like the look of the Prince LV_ and RD5200 valves.
5) Do you have float detent positions for both cylinders? It seems like that might be useful for floating an implement on the ground.
Thanks! /forums/images/graemlins/wink.gif
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
6' FINISHING MOWER (A60430)
6' FINISHING MOWER...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2018 John Deere Z997R (A53317)
2018 John Deere...
