Top and Tilt for DX40
   / Top and Tilt for DX40 #1
JHTFarmer
Lake Charles, La
Case DX40
Anyone know where these might be available online?
I've got two rear remotes that came with my DX40.
I'd like to utilize them. My dealer is willing to supply them, but is estimating $700-$800 for two cylinders and fitted lines.
Does this sound reasonable? I'd like to give the business to my local shop, but not if they are giving me a way too high bid.
   / Top and Tilt for DX40 #2
Call Mark Carter at Carter & Carter Machinery. They sell the top links with the double pilot operated check valves, which are the only way to go. Do a search on TBN and you will find many satisfied customers.
CCM top links
   / Top and Tilt for DX40 #3
What Mad said...absolutely.
If you get top-n-tilt from anyone else, you will not have the best setup. You will also not have the least expensive setup. How Mark does such high quality at such a low price is amazing. If you have to wait awhile because his stock is low, just be patient. He will deliver and you'll be glad you waited.
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
