top and tilt..again ,sorry
   / top and tilt..again ,sorry #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
I am looking for a top and tilt cylinders for a massy ferguson 1540 ..i have rear remotes ,,,i e mailed c & c and didnt get a response ...thanks for any help bruce
   / top and tilt..again ,sorry #2
Bruce,
Mark from C&C will probably get back to you in the near future. That's where I would consider purchasing if I was looking.
   / top and tilt..again ,sorry #3
I talked to Mark about 3 weeks ago and he said at that time it might be as much as 6 weeks before he had any tilt cylinders that were not already sold.
I already have a top cylinder so will just have to wait for the tilt cylinder.
Vernon
   / top and tilt..again ,sorry #4
Why are these so hard to get and in such few numbers?
   / top and tilt..again ,sorry #5
I have been watching the saga of getting the top n tilt cylinders with check valves for quite awhile now. I keep wondering what your suppose to do if one of the cylinders or valves go bad. Sounds like a mess to me. I wonder if deere's or kabota top n tilt cylinders have the same issue with getting the check valves. Or...do they not have the check valves? Anyone know?
   / top and tilt..again ,sorry #6
Ops...forgot to ask does anyone know the cracking pressure on the valves that CCM is selling?
   / top and tilt..again ,sorry #7
</font><font color="blue" class="small">( forgot to ask does anyone know the cracking pressure on the valves that CCM is selling?)</font>
Mark once posted the number. I believe it was 500. He also explained why it had to be this high. Take a look at the thread below and scroll down about 15 posts, then read the entire thread to the end from there.
Why double pilot operated check valves
   / top and tilt..again ,sorry #8
</font><font color="blue" class="small">( I have been watching the saga of getting the top n tilt cylinders with check valves for quite awhile now. I keep wondering what your suppose to do if one of the cylinders or valves go bad. Sounds like a mess to me. I wonder if deere's or kabota top n tilt cylinders have the same issue with getting the check valves. Or...do they not have the check valves? Anyone know? )</font>
The cylinders I got for my L2800 from my dealer do not have ck valves.
   / top and tilt..again ,sorry #9
Ok...great and thanks. I found the valves locally with a 3:1 ratio. They are rated at 2500 psi and the guy said it would give me a little over 800 lbs of holding. $60.00 bucks plus a cylinder will tell me if it works.
   / top and tilt..again ,sorry #10
These are imported. With long transit times, by sea via container ship, the sellers have to project their needs a long way ahead. Even with a 20' container that is a big investment for a small business.
That is what happens when manufacturing goes over seas. Unless it is a high value item, air shipment is out of the equation.
Vernon
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
40006 (A55788)
40006 (A55788)
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A55315)
1995 Ford F-250...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
