Top 3 Point Hitch Linkage (Kama 554)
   / Top 3 Point Hitch Linkage (Kama 554) #1
TobaccoRoad
Mine broke. Anyone know the best compatible option? The center piece is only ~12" long. Thanks Much, Kevin
   / Top 3 Point Hitch Linkage (Kama 554) #2
Not sure what you mean by 'carpetable option'
If it is imperial threads you should be able to buy just the end at a tractor or farm supply store. It may be more difficult if it is metric threads.
However, most tractor or supply stores also sell just the ends that have a weldable stub on them. You then cut the damaged area off of the remaining threads and weld on a new end.
Or you can buy a new complete assembly, it doesn't matter if it is metric or imperial. Probably under $50
   / Top 3 Point Hitch Linkage (Kama 554) #3
My KM554 has non-standard 7/8" top link pins. My link looks just like yours. I put a thin bushing in the implement end and use it with Cat 1 pins. Agri Supply sells a cat 1-2 top link that is cat 1 (3/4") on 1 end and cat 2 (1") on the other. Then put a 7/8 to 1" bushing in the big end where it pins to the tractor.
Otherwise you could weld one up from a cat 1 top link and an end from your old one or a cat 1 lower lift arm end. (Both of those should be 7/8")
Thanks!!! K
Thanks!!!! K
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
1987 International 1954 Elliott ECE 3-65H Boom Lift Truck (A56858)
1987 International...
DECORATIVE METAL GATE (A58216)
DECORATIVE METAL...
2019 Deere 35G (A53317)
2019 Deere 35G...
205196 (A52706)
205196 (A52706)
Giyi 66" Rock Bucket (A57149)
Giyi 66" Rock...
