Toothbar
   / Toothbar #1
jshbryan
Texas
Branson 3820i
Hello,
New to tractors and all of the attachments. I purchased 55 acres last year and am in the process of trying to clean it up. Gave up and went and bought a Branson 3820i with FEL, 6' BB and 6' rotary cutter.
I notice that many of you have toothbars on the FEL. What benefits do you get from a toothbar?
   / Toothbar #2
Welcome jsh and good question for your first post.
Although a toothbar is not 100% necessary requirement, it is one of those items that makes using your FEL bucket a little easier ... a lot in some cases. But it has drawbacks too. I'll point out some pros and cons and I'm sure others will chime in with a lot more information.
If you are digging with your bucket, or picking shrub and sticks, the teeth help quite a bit. They allow better penetration into hard or soft dirt piles and get "under" debris like branches or sticks. This is the major plus as some digging is impossible with a good toothbar. Working with a grapple for shrub removal is wonderful. Downside is back dragging with the bucket lip now not smooth. However, you can use the rear of the bucket to do that like I do. It is removable in most cases so you would have the normal shape of your fel bucket lip back.
Most toothbars have a big thick bar that the teeth are attached to and when you put it over your bucket lip, it adds a lot of strength to the bucket from bending or bowing under pressure. Another big plus to keep your bucket in shape. Downside it's slightly heavier by a 80-100 lbs or so.
Another advantage is if you want to "pop out" small trees or shrubs or even rocks. Hook one or more of the teeth under the rock/root ball or near the bottom of the trunk and pry the tree/shrub out. This works great and fast.
Most guys would agree a toothbar is advantageous for guys who do a lot of digging and tree/shrub removal. It's also easier to a degree to get rocks sliding into the bucket. However, if your going to be spreading manure or gravel and not digging, no toothbar is needed. Then again there are a lot of guys who do all the above without one too.
   / Toothbar #3
I only use mine for digging in the dirt. So, 98% of the time, it's off the FEL.
You need it for dirt digging; don't for most everything else.
Ralph
   / Toothbar
Thanks for the reply. It sounds like a tooth bar is a benefit for what i am doing. 39 of the 55 acres is heavily covered by mesquite and I believe that I actually have more cactus than the whole state of Arizona. A rake bucket also looks to be a good investment/build for me as well.
   / Toothbar #5
Yes it makes a gigantic difference when picking up piles of brush, you will be surprised at how big a pile you can pick up with a tooth bar!
Mike
   / Toothbar #6
I use a homemade toothbar with long teeth in conjunction with a grapple on the top of the bucket when working brush or moving logs around to cut up into firewood and such. The teeth plus grapple are great for picking things up. The teeth also help when cleaning manure out of the sheep barn. They waste a lot of hay so the manure is far from being little round balls of excrement. It's more like digging up a swamp. The straight bucket edge tends to slide over the top due to the hay stems mixed all through, while the teeth let me grab great gooey gobs of the stuff, then the grapple holds it all in or on the bucket while I move it out.
   / Toothbar
I will post a pic that kinda shows what I am dealing with. And before you say it...... I know I need a dozer.
   / Toothbar #8
I will just say that if the few $$$$ it cost is not a problem for you get a toothbar, they come in handi at times.
   / Toothbar
Yum! Stew anyone :D ?
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
