Toothbar on the way
/ Toothbar on the way #1
Paul_in_CT
Connecticut
Kubota B2910
After coming across all the posts about toothbars, I am convinced. I order one the other day and already have plans for projects... /w3tcompact/icons/smile.gif
Thanks for taking your time to pass on it's usefulness
/ Toothbar on the way #2
Right you are....just received mine from Carver (direct from Long) yesterday afternoon. Ordered on Apr 23rd, so that's not too long a wait. Now all I have to do is figure how to make those 3/4" holes in the FEL!
/ Toothbar on the way #3
I used a spring loaded center punch to mark my location and then drilled a 1/8" hole, then a 1/2" hole and finally the 3/4" hole using my Craftsman 1/2" drill. It wasn't bad but not quite something I would want to do everyday. The whole process took me about an hour and a half (drilling and mounting) excluding my trip to the hardware to get extra 3/4" flat washers to use as shims.
/ Toothbar on the way #4
That sounds like an option.....I only have a 3/8th drill tho'. Has anyone used a bimetal 3/4" hole saw? I have to buy something 3/4" in any case and HomeDepot has those at a moderate price. I have an arbor that I ground down a bit to fit the 3/8th chuck.
/ Toothbar on the way #5
I cut this hole in 1" flat stock with a 2 3/8' bimetal hole saw. Lots of cutting oil, steady pressure, and 1min. 15sec.
see attachment
/ Toothbar on the way #6
Hole saw or Unibit will do it. Unfortunately Unibits are a bit expensive.
/ Toothbar on the way #7
lcrans,
I drilled the holes for my toothbar using a bimetal hole saw from Home Depot. Perfect fit and only took about 15 minutes per side.
--Brad
/ Toothbar on the way #8
The hole saw worked fine for me.Slow speed and oil.
/ Toothbar on the way #9
You are one of the lucky ones. I ordered one from them on March 14 and still have not got it. I was told I would have it by the end of March. I donl't think tooo much of Carver as a reliable dealer. As a mater of fact I would not try to deal with them again.
/ Toothbar on the way #10
Mistakes happen, but I'm sure if you give him a call he'd bend over backwards to make things right. Steve's a good man.
Pete
/ Toothbar on the way #11
My toothbar from Carver came in thursday. I put it on this morning, and spent all afternoon digging things up. I used a spring loaded center punch, then a 1/4 inch titanium tipped bit. Followed with a 1/2 titanium tipped bit. Finally, used a 3/4 ordinary bit (with 3/8 drill). It worked fine-just used slow speed and some cutting oil. The toothbar adds a whole new dimension to the FEL.
John
/ Toothbar on the way #12
I did receive the toothbar pretty quickly I guess, considering UPS has to get out the GPS to find us. I ordered a tiltmeter at the same time, and that came in about 4 days. As far as Carver goes, it was my first order so I'm no expert on that....the salesman didn't seem too enthusiastic, kinda like he was bored with the job, but then I've never been in that part of the country for long, so I don't know much about how folks there react to things.........
From the responses I think Holesaw is the way to go...Off to Home depot! It just opened here last week....there goes the bank account.. Oh well............
/ Toothbar on the way #13
Is a "bimetal hole saw" specifically made for cutting through metal?
David
/ Toothbar on the way #14
David,
Typically bi-metal is for metal, but not always. It should say on the package what the hole saw is for. You can also tell by the teeth, bigger teeth for wood, smaller for metal.
Hazmat
/ Toothbar on the way #15
DON: suprised u did not get your toothbar yet, there must have been a foulup. i got mine in 7 days from carver last year.did u call them? and was it charged to your account?
