Toothbar on or off??
/ Toothbar on or off?? #1
Anonymous Poster
Epic Contributor
I have been doing a lot of grading of my property lately. My technique is to make several passes with my boxscraper to create piles of dirt that I scoop up with my FEL. This creates pretty loose soil and some rocks but it seems like my bucket doesn't get even 1/3 full when I make a pass with the FEL. I was wondering it just a flat edge on the bucket would be more efficient that the edge created with the toothbar. Should I take it off for this type of operation??
/ Toothbar on or off?? #2
My loader works much better in some applications with the toothbar removed. Of course, when scooping material on a paved surface is one, but it really surprised me how much better it worked when scooping ballast-sized rocks a dumptruck delivered. The +/- 4" rocks would accumulate between the teeth and kinda plow the intended load out of the way. After removing the bar, the bucket could easily be filled to the brim.......................chim
/ Toothbar on or off?? #3
if i am understanding ur question right , u are having a problem getting a full bucket when trying to scoop up small piles of soil? this is not abnormal. when there is not a lot of substance the loader will want to push instead of fill. don't beleive the tooth bar has anything to do with it. try going into a large pile and lift and curl at the same time, the bucket will fill with or without the tootbar. but maybey i mis understood the question? /forums/images/graemlins/confused.gif
/ Toothbar on or off?? #4
I have individual teeth on my front bucket, as contrasted to a bar. I find it easier to take the teeth off and 'scoop", verses dig. If I'm "digging", then I tend to put/leave the teeth on.
Richard
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
1206 (A64280)
1206 (A64280)
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
HARDEE DB4060 DITCH BANK MOWER (A63291)
HARDEE DB4060...
