Toothbar Installation
/ Toothbar Installation
Re: Toothbar problem, part 2
Here's another shot of the poor fit.
John Mc
/ Toothbar Installation #22
If the clearance is 1/2 inch, I would consider it a problem. The two edges fit tight together on mine and I still have to clean out the wood splinters after working in the woods. With a larger opening you would have stick and about anything else stuck in there. Dont think it would effect dumping of materials. Possible solution is to stuff some metal in there to fill the gap.
/ Toothbar Installation #23
Usually the slots are set up so you can attach the bar to the bucket in such a way so that you only have to loosten the bolts, slide the bar foreward and swing it up out of the way if you don't need it. Problem is that the bolts will work loose, and the bar comes loose when you want it tight. I have always had mine installed so no slippage can occur (on the recommendation of my dealer) and this has provided good service. In other words, the hole in the bucket is at the back end of the slot. I have never felt the need to remove the bar once it is installed. It takes practice, but you can still do smooth grading with the bar in place.the only other reason I can think of to remove it is for scooping loose material off of a smooth surface. Since I never have this situation, I never need to remove the bar.
/ Toothbar Installation #24
John
Your picture looks very similar to the Long Tooth Bar I have. I never did get it down flat without any gap. To get it closer than yours I had to grind some of the weld that holds cutting edge to bucket.
When installing tooth bar I point the teeth of tooth bar down and attempt to lift front of tractor up. This seats tooth bar on bucket cutting edge.
/ Toothbar Installation #25
John,
I purchaced the Long toothbar from Carver for my B2400 with LA351 loader. The toothbar fit exactly as your pictures show with a half inch gap between the toothbar and bucket. I considered that an unacceptable sloppy fit. It would have fit a one inch thick cutting edge, but the LA351 loader has a half inch thick cutting edge. I had the same thoughts, that things would get jammed in the gap and dumping would be affected. I contacted Carver and they double checked that it was the same toothbar that they always ship for that loader. I returned the toothbar and got my money back.
I was suprised to read here that others have the same loader/toothbar combination and say "it fits like a glove". Maybe different people have different standards for how well something fits, or maybe it is a quality control problem. Long does have a quality problem as far as spacing the teeth. While it may not affect the functionality much, the spacing of the teeth was completely random on the toothbar that was shipped to me. The tooth to tooth distance varied by more than 3 inches with every spacing being different. The guy that didn't bother to measure and eyeballed where the teeth should go, didn't have very good estimating abilities.
Andy
/ Toothbar Installation #26
My toothbar is a bobcat bucket bite and it does fit like a glove. No gap at all. That would drive me nuts.
Here is a pic of the toothbar. It was to wide for the bucket so I cut a piece out of the middle and rewelded it. That is why the two teeth in the center are closer than the others.
Gordon
/ Toothbar Installation #27
Gordon
That’s the way mine looks. /w3tcompact/icons/smile.gif Except for the 2 teeth close together. /w3tcompact/icons/laugh.gif
/ Toothbar Installation #28
John, I have a Woods tooth bar that looks to be the same model and fit as the one you presently have. Maybe I am not picky enough but I haven’t found it to be a problem. The gap will fill with dirt almost immediately and I don’t recall brush having ever been a problem. With the Tooth Bar on, the loaders cutting edge is not engaging unbroken soil so the wider profile created at the edge has not been an issue. Actually with the bucket leveled, you will see that the teeth engage the ground about an inch below the cutting edge. Mine has over 300 hours working in rocky terrain with little wear so I would buy another if I needed one. Of course I never remove mine and that may make a difference.
MarkV
/ Toothbar Installation #29
After many years of using toothbars on lots of different loaders.
We have found that a loose and almost slopply fit serves the Easy On-Of concept much better that a Tight-Fit Like a Glove.
As soon as the bucket gets a little banged and dinged on the sides or you start getting a little rust and old hard clay setting up.... the FIT LIKE A GLOVE equals -- much more difficult to take the tooth bar off or to install it.
We encouraged the mfg. to make them as short as they can without having the bars to slip off unintentionally.
This was done after we had a couple of years experience with toothbars that FITTED LIKE a GLOVE complaints and had customers have to shorten the bars or leave'm on all the time.
Lots of opinions..... just pick the one you like...
Best wishes to all you TBNer for a great holiday weekend..
Be safe..
/ Toothbar Installation #30
John,
I agree with Mr. Carver that a slightly loose fit is
better, especially side to side. But I don't know about being able to slide the tip of your finger under it. I don't believe I can get much more than a fingernail under mine.
--Brad
/ Toothbar Installation #31
I bought a toothbar from Carver and have been very happy with both the quality and digging ability. Side to side fit was about 1/4 inch shy which made fitting very easy. It wouldn't slide 100% into the V due to the welds on my bucket lip. I could have ground them down but didn't see the need. It seated deep enough that the small gap left makes no difference. I haven't had it off yet and see no need to remove. I have unloaded manure and mulch from a wood deck trailer with it on without gouging so will probably never take it off.
/ Toothbar Installation #32
John,
I basically got the "sloppy" fit with mine too. On mine I had to make a choice of having a gap between cutting edge of the bucket and the flat edge of the tooth bar that the teeth are weled to (like you have on yours). Or have a gap where the teeth slide onto the cutting edge. I choose to keep the gap where the bucket cutting cutting edge slides onto the teeth. I thought that this would be better and take some of the load of the mounting bolts and keep branches and rocks from getting stuck. I'm not sure if this is the best way as I haven't used it much yet, only 6 yards of boney gravel worth.
I will post a pic of it tonight.
I was not happy with the fit but I'm sure there are many different bucket configuation with different cutting edge angles that these tooth bars have to fit. I hoping it will be alright. My loader is able to lift 1800 lbs. so it will get a good testing.
/ Toothbar Installation #33
Here's the close-up as promised. Although it looks like there is a lot of space between the tooth bracket and the bucket cutting edge it fits pretty tight. No signs of movement. Again I haven't really used the toothbar hard yet, just moderate.
/ Toothbar Installation #34
Another veiw.
/ Toothbar Installation #35
Ok here is a picture of mine and also this picture shows the mount. It's adjustable, reason being as you bucket wears you can still adjust the mount so it still fits like a glove.
Gordon
/ Toothbar Installation #36
Ok here is a much better picture. It's more of a close up.
Gordon
/ Toothbar Installation #37
What Steve is saying makes some sense. I have only had 2 tooth bars but I have used them for 9 years on 2 different machines. Both of them had a small gap between the bucket and the main cross piece on the bar. While some material does get caught between the bucket and the bar from time to time, it is usually not a problem. I have had small sticks (usually roots) and stones get in there, and dirt will usually fill the gap as well. Now I have had the odd piece of wood get in there that gets REALLY jammed in. Sometimes it takes a few raps with a hammer to get it out. But this never seems to affect the use of the bucket, just the end of day cleanup. Frankly, I have never found this to be a problem. What WOULD be a problem is if the bar was actually loose and was able to move. I think as long as the bar is tight on the bucket, any small amount of material that gets caught is irrelvent. As for obstructing the the dump cycle, yes, with loose material there will always be a little that gets caught on the back side of the tooth bar. But we are talking about less than a quart of stuff out of a 5-6 cubic foot dump. The only real problem this causes is with corrosion of the bucket if the material is left in there between uses. Particularly with barn and feedlot waste, That stuff has a lot of acid in it and it will damage the bucket over time if not cleaned out.Oh yea, one other thing that can be a real problem. I saw a guy using his loader to move wet concrete. He allowed the small buildup of material to stay under and behind his tooh bar over night. It took him about 3 hours of banging with a hammer to get it right again. About 30 seconds with a hose the day before would have saved him a lot of greif.
/ Toothbar Installation #38
Really nice!!! That fits BETTER than a glove!
I really like the adjustment.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
2007 Ford F-150 Pickup Truck (A64194)
2007 Ford F-150...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2021 Norwood Towable Lumber Pro HD 36 V2 S/A Towable Bandsaw Sawmill (A64194)
2021 Norwood...
