Toothbar for bolt-on cutting edge: FINISHED!
   / Toothbar for bolt-on cutting edge: FINISHED! #1
RichT
Fallbrook CA
Kubota B26
Too much trouble to remove the cutting edge to use a conventional toothbar and would have to rob a bank to afford toothbar designed for bolt-on cutting edge buckets. So I made one. For reference - its a Kubota B26 with 60in FEL.
Design: Decided on 7 tooth configuration with 3/8 plate 3" wide crossbar. The crossbar would have to clear the bolt-on edge bolts and top weld, sit just behind the top weld (pic1). This required shanks with sufficient length to span at least a couple inches of crossbar width (welding area), and still fit over the bolt-on edge. I made a cardboard mockup of the lower FEL lip & bolt-on edge, then researched shanks at the Fabco website. This website has shank pictures and dimensions. Selected a couple candidates that looked like they might work and made cardboard mockups of them as well. Fitting the mockups together determined that Fabco 2A Series Shank #15625 was very close.
Cost: on a tip I got from this forum I used a Canadian company (Terra Cut Supply Ltd) to buy the shanks/teeth (8002A-C)/pins (RP-H2A). Their prices were lower than US distributors and the parts were shipped directly from Fabco anyway. While placing the order with the salesman he asked me how far I was from Costa Mesa CA (about 30mi). Turns out he had just put a down payment on a BMW at a Costa Mesa dealer. So he asks if I could inspect the car and, in return, they would eat the cost of the parts I ordered. So total cost of the toothbar: ~$30. Even with the cost of the shank parts the total would have been well below $200. Oh - the BMW was an 08 528i and sweet!
Assembly: fabricated the side panels from 1/4 plate, then tack welded a couple shanks to the crossbar to check fit. Had to grind just a bit off the top corner of the bolt-on edge just where the shanks overlap to get a nearly perfect, straight fit. All looked good, so I welded up everything else, attached the teeth (pic2) (lesson learned - attach the teeth BEFORE welding the shanks), primed (pic3), finish coat (Rustoleum gloss black) (pic4), then mounted on the FEL (pic5). Oh yea, and reinforced the FEL holes.
Maybe this will help other DIYers with bolt-on cutting edges.
   / Toothbar for bolt-on cutting edge: FINISHED! #2
You do good work Rich... so when are you going to start using the B26? The loader looks better than some new ones I've seen on Dealer lots...
   / Toothbar for bolt-on cutting edge: FINISHED! #3
Nice job! I just put on a bolt on cutting edge on mine. I'll probably have to do the same if I want a tooth bar. plowking
   / Toothbar for bolt-on cutting edge: FINISHED! #4
Excellent job.
Thx all. I had a slight setback in my tractoring activities about 3wks ago when I unintentionally tested the strength of a ceiling drywall panel. Slipped wandering through the attic. Good news - a ceiling joist broke my fall. Bad news - a ceiling joist cracked a rib. Don't know how many of you guys have had a rib problem, but they aren't much fun. Should be back to normal duties in a couple weeks.
I touched up the loader - grinding and welding the support plates - with the Duplicolor 1620 Chevy paint. As several say on here, nearly an exact match. I tried both the old and new Kubota orange - neither was close.
   / Toothbar for bolt-on cutting edge: FINISHED! #6
I cracked a couple ribs when I fell out of the hammock. In case anyone wants to laugh at you, just tell them that you heard of some fellow who thought jumping into a hammock was a good idea.
OUCH!!
   / Toothbar for bolt-on cutting edge: FINISHED! #7
Beautiful job Rich. I have a bucket with a bolt on cutting edge on my Kubota 4610. Thinking I need to fabricate a tooth bar like yours. Thanks for the post.:)
Bob
   / Toothbar for bolt-on cutting edge: FINISHED! #8
do9es anyone have a website where to get these shanks and tooths?
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2017 FREIGHTLINER...
(INOP) EZ GO WORKHORSE GOLF CART (A51247)
(INOP) EZ GO...
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
toro turf sweeper (A50324)
toro turf sweeper...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
