Toothbar fit on bucket edge
   / Toothbar fit on bucket edge #11
I also just installed a toothbar on my 72" bucket. It was straight as an arrow. I got it from Markham Welding.
Mike
   / Toothbar fit on bucket edge #12
sbd, They are lining you so they don't have to fix the problem. It should be a simple fix though. Take the bar out and lay it on a 4X4, curb, your bucket 5" off the ground, etc. Start standing on it until you work the bow out. I bought bar to build a toothbar and it was bowed when I got it and thats how I took the bow out of it. Hope it helps. MP
By the way. At least put your first name in your profile so people who like to use names can do so.
That rabbit is funny.
Kossetx, The bar that the teeth are welded to is 1/2X4X46 inch. My carcass is not heavy enough to bend it back down flat. I tried that already. Thanks anyhow!!
   / Toothbar fit on bucket edge #14
SDB, Does it go onto the bucket OK with the bow in it?
No, it does not fit. The sides were too high and actually lifted up off of the bucket edge while the middle was bottomed out. I wasn't about to bend my almost new bucket to match the smile the bar had on it. Putting a straight edge up against both was the eye opener.
UPS has it now. It's going back.
   / Toothbar fit on bucket edge #16
A shame. I could have bent it. I just did some last week in preperation for building mine. It was surprizingly easy for me.
   / Toothbar fit on bucket edge #17
The one I made bowed, I placed the ends on two 6''x6'' put my 300 lbs. on it what that didn't take out a 10 lb. hammer did.
   / Toothbar fit on bucket edge #18
I'm with alan on this one with the improper welding practices. They did not do it correctly.
My Markham TB is straight and fits like a glove...only thing required to install is a lineup punch..no pounding with a hammer at all.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2020 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52707)
2020 CATERPILLAR...
2010 Ford F150 (A55973)
2010 Ford F150...
2013 Cummins ISL G 300 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2013 Cummins ISL G...
2017 VOLVO EC160EL EXCAVATOR (A52707)
2017 VOLVO EC160EL...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
