Front-End Loader tooth or stump bkt
   / tooth or stump bkt #11
I bought the grapple bottom below, which has long tines you can jam into the ground below the roots, & then try to lift (usually doesn't work), or instead pry:
Set the grapple bottom at about a 45-deg downward angle, push the tines under the roots ... if possible push down to the point where the front of your tractor is off the ground, so you can use its weight to help pry ... then curl the bucket. The weight of your tractor should push down on the back of the grapple bottom & curling your bucket will allow the tractor weight to pry up under the roots.
I got the 72" wide model, but if I had it to do over, I'd get the 60" model. And usually even the 48" would work, but I also use it to haul debris around, where wider is better.
   / tooth or stump bkt #12
LB
A few years ago I bought a toothbar 72" and a stump bkt. from Markem for my 6000lb machine. The tooth bar Is a very good investment for The $.At the time I had 5 arces of thorny crabapples to clear. I found it better to cut the bigger trees 4-6" dia.and doz/ push the roots .Sometimes I had to scratch um up with a bh. I had thought a stump bucket would be useful too... but as it turns out no so much for this task. I've found that my stump bucket is excellent at trenching a ditch ,trans planting single bushes & small trees . furrowing etc. but not land clearing. I've used pallet forks especially the ones Brick/masonary companies use and do what Beppington said.
Most recently I've built a grapple for my toothbarred bucket on the front and built a box blade/ ratchet rake combination on the TPH . This is what I'm currently using to clear ground ....
Ak9
   / tooth or stump bkt #13
Dustin, I don't know for sure, but, just guessing, I probably don't have enough tractor to operate the woods. Thanks for the info though.
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
Toyota 7FDKU40 7,350lb Forklift (A55973)
Toyota 7FDKU40...
