tooth bars
   / tooth bars #1
bowhunter3030
Collinsville, IL.
Kubota Grand L4060hstc & Kubota B2601
I need to know which removable tooth bar you would recommend for a B3030 & 60" bucket that I have ordered. I want to get one of quality. Also, approximate price I should pay for it. thanks
   / tooth bars #2
I bought a Woods 61" tooth bar for my FEL and it was $300 dollars. Works great! /forums/images/graemlins/smile.gif
   / tooth bars #6
Try using the search feature. This has been discussed quite a bit in the past few months. Good luck with your search
   / tooth bars #7
EZ toothbar from H&H Sales .
Since the 60" bucket is lighter weight than the 54", the extra strength of the V edge may be especially welcome. Price about the same as Woods, W R Long, etc., more than Markham. Check their website for a dealer in your area.
   / tooth bars
I like the fact that this tooth bar has an edge of its own. This will protect the bucket edge. Thanks
   / tooth bars #9
bowhunter3030,
I've been using my extreme duty H&H toothbar since november on an 84" bucket attached to a Kubota M9000 and I love mine its first job was to help me move 1,000cu yds of hard packed dirt and rocks. I don't know if I'd have torn up the lead edge of my bucket or not but there is some security in knowing that I've added more beef up front rather than just the teeth attached to the bucket like most of the toothbars mount. I know there are a lot of folks using the other ones and only Henro and Aloha for sure have the H&H like mine and everyone swears by theirs and none indicated any lip damage when I was trying to decide which to buy. I have to believe that when you start prying stuff out of the ground a little extra metal up front won't be a disadvantage. I don't forsee ever taking mine off I just use the bottom of the bucket to smooth stuff with although that seems to be one of the selling points for all of the toothbar manufactures it looks to me like they ought to make a bucket for ag tractors with the teeth being integral with just the tips being changeable if you broke or bent one.
Steve
   / tooth bars #10
Mine is similar to the H&H link below. I take mine off in the winter and replace it with a large flat steel cutting edge for clearing snow. However, the tooth bar is like night and day in regards to digging ability on a loader bucket. They are dangerous though...My teeth are very sharp and will basically destroy anything they touch....including your skin if you bump into one of the teeth with only a tee-shirt on. I cut my shoulder pretty bad just rubbing up against one of the teeth. They'll cut right into any wood or siding you may brush up against....I snagged just a small piece of my driveway pavement with a tooth and it ripped a whole section out of my barn entry area. /forums/images/graemlins/mad.gif Generally, I'd have to say it the cheapest and most useful "attachment" you can buy.
2003 Club Car Electric Utility Cart (A56859)
2003 Club Car...
207273 (A52708)
207273 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2000 Freightliner Discovery 36T 36ft. Class A Motorhome (A56859)
2000 Freightliner...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
Welcome to the Ranch Metal Sign (A57454)
Welcome to the...
