Tooth Bar
   / Tooth Bar #11
I'm sure it WORKS just fine. But all those mounting bolts are silly when there is an alternative. And the non replaceable teeth (looks like) doesn't make much sense either. But then most folks will probably never wear down the originals...
   / Tooth Bar #12
<font color="blue">...all those mounting bolts are silly when there is an alternative. And the non replaceable teeth (looks like) doesn't make much sense either... </font>
The teeth that are being used... DON'T SLIP OVER THE BUCKET'S CUTTING EDGE... (in essence clamping itself to the bucket), therefore he has to use all those holes/bolts to secure the assembly...
I agree... it's probably a "cost factor" on why this builder uses these non-replaceable/non-standard teeth, instead of what is commonly used on the $300. + toothbars...
If this builder goes to the "normal" teeth, and uses a 2-bolt approach for securing, and then sells it for $160... Then he'd be cooking....! /forums/images/graemlins/wink.gif
   / Tooth Bar #13
I don't think most users will be thrilled with the idea of drilling a couple dozen holes in the bottom of their buckets, especially if they take their tooth bar on and off as I do. Personally, I think I'm happier with mine for the extra $100 and the twenty fewer holes. /forums/images/graemlins/smile.gif
   / Tooth Bar
Thanks everyone for your opinions. I've decised to pass on this tooth bar and get one that has replaceable teeth, slips over the front edge of the bucket, and is held im place by two bolts, one on either end. I'll pay a bit more, but probably be happier in the long run. Thanks again.
   / Tooth Bar #15
I'd like to second the those sentiments by Jeff. You guys haven't steered me wrong yet. I never even thought of the bolts being such a hastle let alone drilling all the holes. The removal as suggested above is also a concern, particularly if your picking up the stuff Henro shows off in his picture. I'm cancelling my order.
Joe
   / Tooth Bar #16
I would have to agree. When you break one of those teeth off you might as well throw the toothbar out. It would take a while to drill all those holes in a bucket. I would pay the extra for a better toothbar. It will be worth it in the long run.
   / Tooth Bar #17
As always, a good discussion that raises a bunch of relevant issues to mull over. I have decided, based on previous posts, to buy some forged combine guards, which are basically 6" long "tooth pairs", $6 each at TSC, and weld them to a strap of 3/8" steel, which I will bolt to the lip with maybe 3 or 4 elevator-style bolts. I hope to do all this for about $50-60 total (figuring 0 for the welding). Since I have a special purpose- busting up ground-up asphalt road material piles, it oughta work. But the discussion is great! Hope to post a photo when I get it on the bucket.
   / Tooth Bar #18
The teeth on this tooth bar are not a whole lot different than the shanks on the small back hoes. About the only difference is that they don't have the pin on teeth to cover the shank. The shanks on the small backhoes will bend and will break off. When they do, you just weld them back on or replace them if they are bent to much.
   / Tooth Bar #19
Ok........I just ordered my toothbar today. But it is the type that slips over the cutting edge. I think I'll be happier with that one. 54" for $270+/- a buck or two. with shipping and tax. I could have had it delivered here to the house, but the dealer is a member here and I want to meet him, so I'll go to his shop and get it. Besides maybe I can talk him out of a hat or T-shirt /forums/images/graemlins/grin.gif
Jerry
   / Tooth Bar #20
It is more common on some skid steers to have a bolt-on cutting edge. Then you replace the cutting edge with this bolt on tooth bar. I'd buy it in a second if I had that type of bucket.
As others stated, it's kind of a mess if you don't already have the holes drilled, & wish to mount/ dismount it often.
As to the sickle guards, they are mallable cast iron ( designed to be bent with a hammer) and probably will not last very long at all at a dirt/ tar/ rock worker. Might do the one job fine that the person has in mind with the tar, but do not plan on a long-lasting item. Just a heads up to others thinking of it.
--->Paul
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
232 (A52708)
232 (A52708)
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
PALLET OF MIXED METAL, FLAT & ROUND STOCK, ANGLE (A52708)
PALLET OF MIXED...
LARGE METAL RACK W/ 5 LEVELS (A58374)
LARGE METAL RACK...
2014 Hyster H90FT 8,000lb Diesel Forklift (A55973)
2014 Hyster H90FT...
