tooth bar width
/ tooth bar width #1
tcb
west alabama
kubota L4400
ups girl just delivered a tooth bar i bought of ebay. price was to good to pass on, less than parts and weld one up myself. i planned on having to widen it, but, it is within 5/8 of an inch of fitting perfectly. question is should i cut and weld in a spacer in the middle like i planned or just shim the sides, bolt it on, and go. thanks in advance.
tim
/ tooth bar width #3
Shim it out and go for it! The holes you drill will remain in the same position if you decide to add the additional 5/8". Just use some good quality bolts and you should be OK either way.
/ tooth bar width #4
Yep, like the other guys said, just shim with a couple of washer on either end.
/ tooth bar width
thanks for the replys guys and confirming my thoughts. this was a bargain for a never used bar. on purchasing i planned on making just right but on inspection it seemed like a waste of time. now lets go dig something up.
tim
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
2007 International 8600 Parts Truck (A63689)
2007 International...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
