Tooth Bar question
   / Tooth Bar question #1
quadpa1911
Where the Redwoods meet the Sea (CA,OR.boarder) in
Kioti DK45S
I have a DK45S with a KL451 FEL 72" bucket I was looking into a tooth bar when the dealer I bought the tractor from told me that it would tear up the loader and bucket. I see a lot of folks here using tooth bars any problems and do's and don'ts?
   / Tooth Bar question #2
None so far.
If the bar is installed correctly I don't see how you can damage the bucket. The load is carried on the existing cutting edge and fairly well distributed on most of the designs I've seen.
Don't let the dealer scare you. If you use common sense there is no risk to your tractor or loader.
   / Tooth Bar question #3
I've had a tooth bar on my 45 for two years with no problems. I've dug shale and dirt with it, you just have to remember that it's not a cat or excavator and use it accordingly.
Quadpa---Welcome to Tractorbynet, I like your quote!
   / Tooth Bar question #4
Howdy I installed a toothbar on my KL120 and have moved tons of dirt, dug up huge rocks and several small trees with mine. It is still as good as new would'nt be without it now.
   / Tooth Bar question #5
quadpa,
You can tear up any loader or bucket with a toothbar; even on a skidsteer.
My buddy has a couple of NH Skidsteers and a Toro Dingo. All have toothbars and all 3 have a tooth that's bent and one has some damage to the bucket. It depends on what kind of abuse you do. He's equipment is used for commercial work and his employees don't give a hoot what happens to the equipment.
When I was tractor shopping, even the Bota dealer told me he recommands toothbars on tractors for dirt work. That was even on the BX SCUTs. And believe me the buckets on the BX are made of think steel.
BTW, does your dealer even carry toothbars?
   / Tooth Bar question #6
I would say just the opposite.
A bucket with a toothbar will have less stress than the bucket without one.
BTI
   / Tooth Bar question #7
I have a DK45S with Markam toothbar. Not only does it reinforce the bucket cutting edge it also breaks ground better so you spend less time ramming & spinning. And it removes in 5 minutes if you want to. I can't imagine anyone trying a toothbar & not seeing advantages to having one. MikeD74T
   / Tooth Bar question #8
Don't have one, but would think tooth bar would make rock pickin a little easier?
   / Tooth Bar question #9
Joel it helps a bunch with rocks. I've got some sandstone in the back yard and it really helps having the teeth on there. I can sink one or two teeth under the rock, curl the bucket and slowly back out. I usually get it out the first or second time. I'll post some pics later in another thread showing the sizes of rocks I've been able to pull out.
   / Tooth Bar question #10
DK45SE w/ Woods toothbar . . . works fine.;)
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
Hobby Farm Manure Spreader (A50515)
Hobby Farm Manure...
John Deere 843 Corn Head (A50514)
John Deere 843...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
Tarter 4' 3 pt Box Blade (A50515)
Tarter 4' 3 pt Box...
