Tooth bar is a little short
   / Tooth bar is a little short #11
<font color=blue>Do you think if I center it and add some washer's to each side it would be OK?</font color=blue>\
I got my toothbar from Carver and it's about 3 washers short. I put the toothbar on slightly offset to one side so I only have to put the washer on one side.
   / Tooth bar is a little short #12
Hazmat, check out this site to see if it answers your plumbing questions:
<A target="_blank" HREF=http://www.factsfacts.com/MyHomeRepair/PipeNoises.htm>http://www.factsfacts.com/MyHomeRepair/PipeNoises.htm</A>
   / Tooth bar is a little short #13
I think they leave the sides short so that there is no question that it will fit inside the bucket,causing less problems and dis-satisfied customers,as a couple of guys have said,most of the pressure is applied to the cutting edge and the bolts are just stopping it from falling off.
Well, I will do the washer thing. Plan to be able to remove it at will so I may mount it and then spot weld the washers together with the toothbar so I don't have to fight them everytime I decide to remove and re-install. Thanks to all for the input......
Tom
   / Tooth bar is a little short #15
bmac & hoiser daddy
thanks for the info & link. It was the shower faucet. Of course last night when I was prepared to take a look at it, it didn't make any noise. I think it sensed that I knew what was wrong with it/w3tcompact/icons/smile.gif. If it acts up again, I'll know what to do.
   / Tooth bar is a little short #16
My toothbar fit perfectly in the bucket but the shoulder bolts they supplied with it have a thicker shoulder than the thickness of the flange on the toothbar + the bucket side. When the nut is tightened against the shoulder of the bolt it is not tight against the bucket and bar mounting flange. I don't know if I should add washers so to take up the gap or just leave it the way it is. The instructions did not address this. What would you do?
Thanks,
   / Tooth bar is a little short #17
Don, I think I'd just get a different bolt to make it fit right, but adding washers is certainly a viable alternative.
   / Tooth bar is a little short #18
Thanks, Bird. I have two 1" washers that I bought for this but I was debating whether to use them.
Well, I mounted the tooth bar on the loader Saturday. Drilled 2- 3/4" holes in the bucket with a hole saw, added a few washers to fill the gap on each side and tightened up the bolts. Boy, did that make a difference in digging saplings out by the roots and popping rocks out of the ground in the field. Wife is going to have a he11 of a rock garden if I keep digging up rocks.
Sunday, a friend wanted me to help load sand and stone from a pool area they just tore down. I decided we didn't need the tooth bar so we took it off in just a few minutes.
Another great tool in my arsenal.......
Tom
   / Tooth bar is a little short #20
Tom,
How much did the dealer charge you for the tooth bar - if you don't mind my asking? I am very interested in one of these but the Deere guy in my area is not a pleasure to deal with.
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2013 DODGE CHARGER SEDAN (A56129)
2013 DODGE CHARGER...
2002 Ingersoll Rand P185WIR Towable Air Compressor (A55851)
2002 Ingersoll...
2012 PETERBILT 367 (A55745)
2012 PETERBILT 367...
