Tooth Bar information needed
   / Tooth Bar information needed #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
I am purchasing a BX 22 shortly and was reading about the tooth bar for the FEL in other posts. I asked the selling dealer about this and he said that he knew of none for the BX series tractors, but could adapt one from the Bobcat brand. Can anyone telll me what brand will fit with the least amount of hassle and expense? Also, are there any suggestions as to what accessories or options to order with the tractor? thanks
   / Tooth Bar information needed #2
I just got my BX22 with a toothbar on it. I believe the dealer said it was a Woods model.
   / Tooth Bar information needed #3
Junkman,
Click on this link Carver Equipment
Then select the W.R. Long loader attachments title. I purchased a 48" bar for my BX22 and I am very pleased with it. It is quite beefy and a must have if you plan on doing any digging with the FEL. If my memory serves me right I paid $285. You need to drill (2) 3/4" holes in the side of the bucket to attach the unit. Takes 2 minutes to remove and put back on.
Tom
   / Tooth Bar information needed #4
welcome to the forum! and check out toms post . i got my toothbar from carver. it is made by WR LONG.
   / Tooth Bar information needed #5
I got my W.R. Long tooth bar from Carver also. Quick/easy to install and remove. Works great!
John
   / Tooth Bar information needed #6
I just bought a BX 22 from Don Bales Kubota in Lowell, Indiana and ordered one from him. It's made by FFC Attachments in Lee, Illinois. They custom make them for any bucket size. You give them the inside dimensions (inside width) and thickness of cutting edge, and they make them to fit. The teeth are cut to fit over the edge for a stronger tooth bar. You drill 2 holes in the sides of the bucket, and on it goes. It has replacable teeth that are attached by a roll pin. Replacement teeth are available at Farm and Fleet. Cost was $258.00 if I remember right. It was direct shipped to my door. I don't think they sell direct, so you might have to find a dealer to order thru. FFC phone number is 800-747-2132
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
B&W 5th Wheel Hitch (A53117)
B&W 5th Wheel...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
