TOOTH BAR FOR FEL TC40A
   / TOOTH BAR FOR FEL TC40A #1
MAYOR8020
bath, ny steuben cty.
new holland tc 40a
I want to put a tooth bar on 16la fel i have 72" bucket w/ xtra bolt on cut edge i want to leave on the xtra edge and slide the tooth bar over all
does anybody know of a good make that can achieve this i live in ny so closer to area the better for shipping reasons thanks nfor help
   / TOOTH BAR FOR FEL TC40A #5
MAYOR8020:
NH does sell a bolt-over the bolt-on cutting edge toothbar. They are pretty expensive. The "fit" is less than perfect (~58" long and the toothbar does not come in contact with the cutting edge except at the toothbar teeth weld areas). It appears that the toothbar was really designed for the 60" standard bucket. I had to drill out (no big deal) two new side mounting holes in the bucket and get longer carriage bolts to make it fit. Although the "fit" is not perfect; it has held up to the tasks I have subjected it to so far. FYI- I have a HD QA 60" bucket. Jay
   / TOOTH BAR FOR FEL TC40A #6
Berlon makes a toothbar that will fit over a cutting edge, only problem is since it isn't one of their buckets you need to take your bucket to them and they are located in Wisconsin. I recently took photos and measured my bucket indicating where all attachment bolts are located and I am going to ask them if they will make one for me from my info. Of course I will have to be held responsable for any non-fit issues resulting from my measurements. Actually Berlon would sell the components if you want to weld the teeth in the correct location yourself.
THANKYOU i will try them and see waht thay can do
did your bar fit good and is it rugged thanks dws
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
(1) HD 26ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 26ft x 24ft...
2019 JOHN DEERE 8295R LOT NUMBER 183 (A53084)
2019 JOHN DEERE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
(1) 24ft Free Standing Panel (A51573)
(1) 24ft Free...
