Tools
/ Tools #1
fredflintstone
michigan
cub cadet LS4140
hey yall was looking at getting a 3/4 socket set for my 4140 but wanted to make sure im going
in the rite direction are all fasteners metric? would think so but double checking first as 3/4
in not the cheapest set to get. thanks all
/ Tools #2
Yes metric. Why do you did 3/4 drive set? Harbor Freight has a jumbo set 59.99 for a 20 piece set. I have been able to do everything 9n mine with a 1/2 set. I do need to get a torque multiplier. If you need something in a size that you can not get 1/2 " just get that socket and an adapter
/ Tools #3
I have an R3039H and I only use my metric wrenches etc on it.
Are you talking a 3/4" drive socket set?
I've got a set of 1/2" drive sockets up to 36mm and have not needed anything bigger.
I do have a 3/4" drive SAE socket set up to 2" but seldom have a need to use them.
/ Tools #4
I have not seen anything bigger than a 24 or 27. I would not think a tractor one step up would need anything bigger
/ Tools
thanks for the info. was just thinking 3/4 drive would be the way to go. I was thinking torque on a half inch bolt is north of 100 foot pounds
and a 3/4 drive would be better suited for that kind of pressure.
/ Tools #6
The lugs nuts are above that just get a torque multiplier or old school big cheater pipe and tighten till you can't move it
/ Tools #7
3/4 set will be to bulky to do anything but the wheels. get a 3/8 and 1/2 inch set and maybe impact set for the wheels. after you have used them some I bet you will pick 3/8 set first
/ Tools #8
I'd go 1/2 drive. I only use a 3/4 drive set when I need a bigger socket than I have in 1/2 which is a 1-1/6 and a 21 mm. Also I don't own a 3/4 impact gun and it would be much more expensive than a 1/2 drive.
/ Tools
im used to using a 3/8 ratchet n 1/2 impac every day at work, but now a 7/8 bolt gets torque at 141 foot pounds
what size are the loader bolts? from my exp when im reefing that hard I would rather have the
length and added ridgedity of a 3/4 breaker bar in my hands, beleave me ive broken the head on a 1/2
Armstrong breaker bar, from now on when I have something bigger I want the 3/4, that's at work and do not
have a 3/4 drive at home.
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
CAT HM415C Mulching Head (A65579)
CAT HM415C...
Power command Transfer Switch (A62679)
Power command...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
