Tools for rebuilding Injection pump
/ Tools for rebuilding Injection pump #1
phorvati
I have a CAV DPA rotary distributor type injection pump.
Does anyone have a link for buying "special" tools required to take it apart and put it back together, like the timing tool. Cav manual references tool part numbers which I cannot find anywhere.
/ Tools for rebuilding Injection pump #2
Pretty specialized equipment. Best to have a professional fuel repair shop rebuild it. They have all the equipment to test the pump after assembly and tweak it for best performance.
/ Tools for rebuilding Injection pump #3
X2 if you need the special tools then you need the test bench to calibrate the pump
Jon
/ Tools for rebuilding Injection pump #4
having worked with injection pump rebuilders for the last 20 years even if you found the tooling it would cost you 4 to 5 times more than getting a shop to do it. one cat pump used here in the south 1 rebuilder bought the tool and all the rest send them to him for building and even as already mentioned after building you will need test stand for calibration. if your having problems finding a builder post where you live can put you in touch with someone close to you.
/ Tools for rebuilding Injection pump #5
Injection pumps (and injectors) are the two rebuild jobs best left to a specialized shop. Youy have precision lapped surfaces and all sorts of specialized setting and tools.
Don't cheap out, do it professionally. Just getting a gear drive pump back in time (in relationship to the gear train) can be a royal PITA on some engines....
/ Tools for rebuilding Injection pump #6
Where did you find a manual? I have a CAV Lucas pump on my backhoe. Mystery item, factory manual has zero info re what's in it, replace it is all they have to say.
Reminds me of those old maps that had "HERE THERE BE DRAGONS" around the edge. Don't mess with it, you're too stupid I guess.
Joe H
/ Tools for rebuilding Injection pump #9
that is all well and good but there are some that have to have special tool just to REMOVE the pump from the tractor! One that comes to mind is one on a AC 175. Dad's 175's pump is leaking and he can't get the tractor to the dealer(dealer being 30 mi. away, it is too far to drive and too expensive to the dealer pick it up) he has been unable to find the tool to pull the pump so he can get it rebuilt.
I guess to each its own, I didn't ask if i should do it, I asked where to buy tools. Thanks for all the warnings.
I am in the process of "re-building" CAV DPA, and I will also look into how to calibrate, which parts of the pump make sense to calibrate, tools you can buy for a reasonable price to do all the stuff at home.
By "stuff" I mean take the pump apart, inspect all the recommended components as per manual, put it together, and complete the calibration procedure on all recommended components as per the manual.
I might have shot myself in the foot by taking the pump apart w/o completely understanding all the intricate details, but after few weeks of gathering research material and understanding how pump works, I feel enlightened and happy that I understand how it works. I wont know for sure until i fire it back up but until then, for those who are daring enough to venture into this...
By far the best description on how it works.
http://transportation.centennialcollege.ca/oduffy/fuels/HD fuels 3/distributor.pdf
The best re-build manual with clearest pics...
www.solidebolide.nl/downloads/CAV Workshop Manual fuel-injection-pump.pdf
Good photos on how to take Bosh pump apart.
Bosch diesel injection pump rebuild
Some CAV Lucas manuals with steps of the calibration procedure:
Index of /manuals
Tools, and pricing...
http://marbedbook.com/4/upload/222_en.pdf
Lucas & Hartridge
Happy tinkering!!!!
/ Tools for rebuilding Injection pump #11
Good Afternoon phorvati,
It looks like youve done your research !!! Good job...
Best advice, take plenty of pictures and make sketches and take notes and you will get it done ! ;)
When I was rebuilding one of my old Farmalls a few years back, the hydraulic "Touch Control " needed rebuilding. A number of my friends told me to take it and get it professionally done...
I bought the rebuild kit from Case IH, and got through it just fine, take your time and you will do it ! :)
Good Luck !
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
2020 Godfrey Marine Hurricane Boat w T/A Boat Trailer . (A61574)
2020 Godfrey...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2017 Ford F-250...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
