Toolcat wheels
/ Toolcat wheels #1
GRASSMAN
I bought a Bobcat SB 200 72'' blower for the Toolcat and it works great! Now need a bit more traction, pretty impressed as it is, but know it can be better.
I need some info. I read here that some are using ''truck tires'' vs the standard OEM tires. Unlike other posters, that are saying they have 6 bolt 5'' pattern, mine is 6 bolt/studs, measures 6'' with a 41/2'' center hole(that is 6'' measuring stud to stud) These are OEM wheels tthat came with my 2003. So where do I find wheels? Ford 1/2 ton? Dodge? Chevy 1/2 ton are 5''. Not sure why the difference?
Thanks
/ Toolcat wheels #2
I have the same set up and use 900 lbs of sand bags in the bed for ballast. Gives me all the traction I need. My drive is a steep grade.
/ Toolcat wheels #3
I use 6-hole trailer wheels with LT235 (or 245)-75/15 tires. For trailer wheels I bought new white modulars for around $25/each at a local place that sells trailer parts. Seems to me that the bolt pattern is 6 on 5.5...but I don't remember for sure. I'll try to remember to measure later today and post the results. I'm also chained-up all around. Traction is awesome...especially with ballast. This year I'm not using ballast, though, as traction for my application is fine without it. When I did ballast the TC, I used 9 of those 70 pound landscape blocks.
Update: Tire Size: LT235-75/15 (Load Range C). Bolt pattern: 6 on 5.5. Hole diameter in center of wheel: about 4.25". I use the stock industrial tires for 8 months out of the year and the LT tires with chains the rest of the time. The LT tires/wheels were cheap enough that they are dedicated for Nov-Feb and I don't ever take the chains off those tires...they just live in the back of the shop for eight months. If you want to go with a Load Range D tire, you might have to step up to something like a LT225-75/16. I think they are 29"-30" O.D. Fortunately, 16" trailer wheels are easy to find. Tirerack.com has a boatload of tire dimension data available online. Also, when measuring bolt circle, make sure you are measuring center of stud to center of stud.
/ Toolcat wheels #4
Could studded tires be used in place of tire chains? Would be less agressive, especially if on cement, asphalt ect. Does anyone even sell studded tire anymore?
/ Toolcat wheels #5
Sure, around here you can get them all day long. The last set I bought were at Big-O tires.
DEWFPO
/ Toolcat wheels #6
For the first few years I ran truck tires that were studded on both TC's. They will work if you do not have a steep terrain to navagate. In the end, the studs were not enough and we have gone to non studded truck tires and very agressive chains on all fours. Huge difference...
/ Toolcat wheels
Spud,
Thanks for the info. Sorry I didn't reply sooner. Been really busy here lately with a lot of snow/ Blower about paid for:thumbsup:. Will check out some trailer wheels to try to finish my set up. THANKS
