Toolcat Series-C Unable to access Float for Boom
   / Toolcat Series-C Unable to access Float for Boom #1
Mike Br
Toolcat 5600 - Series C, Turbo, Hi Flow
HI - just joined the forum as a new owner of a 2006 Series-C and was hoping some experienced owners might be able to help me out.
While the machine is a 2006 with about 1800 hours, it appears to have been well maintained - motor runs well and everything seems to work as expected - With the exception of the boom float...
My operating manual describes accessing Float as follows:
- Raise Liftarm and tilt bucket forward
- Push joystick all the way forward until it locks into detent position to engage the float. the lift arm will slowly lower.
My problem is that I can't seem to feel/access a detent position that the joystick locks into.
Asked the former owners and he acknowledged that he also was unable to access float and had asked the person he purchased it from who said he he didn't think the machine had it. As the operating manual suggests it was a standard feature, am left wondering if something might be broken or perhaps more likely my lack of experience is causing the problem.
Searching through the forum I found one other example of a mysterious float problem for a series-C which on inspection by the dealer turned out to be a hydraulic block installed by original owners. I guess that is possible here as well, but I thought this seemed somewhat unlikely as I am not show it would explain the lack of my finding/feeling a mechanical detent described in the manual.
Welcome any and all suggestions around this as well as other advice for a first time toolkit owner who has limited bobcat and skid steer experience.
   / Toolcat Series-C Unable to access Float for Boom #2
i have an 05 C. never have lifted the boom to get it to float. I always drop the boom down, say when you have a mower on, or your bucket. get the tool where you want it and then push forward with the joystick, it will "feel" loose and stay forward, the boom then floats. very noticeable when you back drag with a bucket. in my opinion lifting the boom up and going to float seems dumb. I have never read the manual regarding this but, I would think that if you lifted a mower up in the air 2 feet and then pushed forward on the stick it would drop like a rock. sorry I don't have more.
   / Toolcat Series-C Unable to access Float for Boom #3
I have had (float) detents fail on quite a few different machines. They just wear out and not always when very old it seems. And the assembly never even appears worn. I guess the tolerences are super tight. Usually a quick fix. A kit, that goes on the valve spool.
Hint. Grease those balls prior to insertion, so they stay in place. Worst thing would be to loose them.
   / Toolcat Series-C Unable to access Float for Boom #4
on my 2005 toolcat pushing the joystick forward firmly engaged the float, never tried it with arms up and not sure why you would do it this way,
   / Toolcat Series-C Unable to access Float for Boom #5
   / Toolcat Series-C Unable to access Float for Boom #6
I always use the float when the attachment is on the ground, not in the air also. On my 2008, I find I have to quickly push the stick forward for float to engage but it always does.
DEWFPO
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
CASE 610 Sprayer System 2000 Gallons (A55315)
CASE 610 Sprayer...
UNUSED FUTURE HYD AUGER (A57193)
UNUSED FUTURE HYD...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
UNUSED SDLANCH SDLL50 STAND ON SKID STEER (A57192)
UNUSED SDLANCH...
UNUSED FUTURE HYD 12" AUGUER (A57193)
