Toolcat Rims and Bolt Pattern
/ Toolcat Rims and Bolt Pattern #1
1965tontruck
I have been reading a lot of past posts regarding light truck tires for the Toolcat. In addition, I am also taking not of rim size for those tires. More specifically, bolt pattern. It seems to me that everyone had posted that a 6x5.5 bolt pattern is what they have used.
I scored a set of Toyota Tacoma rims and when measured they are 6x5.5. However, when I tried to test fit them onto my Toolcat (series A), they would not fit. When I measured my rims, the bolt pattern is 6x6!
Did Bobcat change the wheel hubs for later models to the 6x5.5 pattern or am I missing something regarding installing that pattern on my Toolcat? I have subsequently looked for the 6x6 pattern rims and they are very hard to find. Seems most are used on farm implements and have severe offsets making them practically useless for the Toolcat.
/ Toolcat Rims and Bolt Pattern #2
What model Toolcat do you have?
Also, don't forget to get the correct offset for the rims.
DEWFPO
/ Toolcat Rims and Bolt Pattern #4
I put the calipers on our series F, they are 6x5.5 with a 4-3/16 center hole.
/ Toolcat Rims and Bolt Pattern #7
My 2009 Series D (purchased in 2008) has the same tires and rims as Xfaxman. 6X5.5"
DEWFPO
/ Toolcat Rims and Bolt Pattern #8
My 2013 F series is just like the rest. How are you measuring?
DEWFPO
Thanks - so the 6x5.5 rims have been around for a while.
/ Toolcat Rims and Bolt Pattern #13
Were you able to find the type of 6 lug, 6" on center rims you needed to mount load E truck tires?
Yes - through the link you provided above plus a fee other sites. However, I have not been able to find any without huge offsets. Maybe I will start to check some farm equipment auctions and see if I can locate any rims.
/ Toolcat Rims and Bolt Pattern #15
I finally did the switch to truck tires, Toyota Tacoma 265/65r17 on 17x7.5 +30mm offset wheels. Fit with no rubbing (i've driven on them loaded off road since and nothing seen even with lifting tires off the ground in ditches).
Full video on the install and findings/learnings
E-Z TRAIL HEADER CART (A64278)
E-Z TRAIL HEADER...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
UNVERFERTH 6R36" RIPPER / STRIPPER (A64278)
UNVERFERTH 6R36"...
2017 Hyundai Sonata Sedan (A64557)
2017 Hyundai...
1998 Toro Groundsmaster 223D 52in. Commerical Riding Mower (A64194)
1998 Toro...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
