Toolcat heater control checking
   / Toolcat heater control checking #1
laurencen
Veteran Member
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
does anyone know how to check the heater valve on the Toolcat, the system looks simple, variable resister in the dash and ball valve under the drivers seat, mine is wide open for heat, how does the potentiometer work with the valve, I have voltage on one wire but should I see a voltage change as the dial is turned?
   / Toolcat heater control checking #2
No experience with that problem.
Do you have an update?
nothing yet, the dealer has no idea how it works either, the service manual shows how to remove the module but nothing how to test
this weekend I will switch the parts from my 590 and hopefully figure what is not working
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
Root Grapple (A50322)
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
197637 (A50459)
197637 (A50459)
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
