Toolcat for Spouse
/ Toolcat for Spouse #1
Haoleguy
Platinum Member
SE Connecticut
JD 5325; Landini Mistral 50
With every spare minute we can afford my spouse and I work our relatively new property(42 ac) to clear an overgrown field(6ac) and the trails around the property. I operate a JD 5325 with rootrake/grapple, BH, and rotary cutter to handle the larger jobs. I'm a lucky guy as my spouse has been manually clearing vines along the many rock walls. It looks great but with many long runs of wall my concern is that she is fighting an endless battle. I would like for her to have equipment that is multifunctional and relatively safe as she clears and rebuilds the walls. I believe the Toolcat may fit the bill now and move her into the future when she begins to build relative large garden areas. Most UTVs seem to be low in the U category. The other possiblities are a narrow tractor on tracks(New Holland) or a skid steere. Again functionality, easy use, and safety are in consideration. Is the Toolcat a good alternative to a tractor for the spouse? I want to make sure she stays engaged with the property work. Thanks for to the adminstrator for adding this category. Your suggestions/feedback is welcome....Aloha
/ Toolcat for Spouse #2
<font color="blue"> functionality, easy use, and safety are in consideration </font>
I think you've done your analysis well. I'm far from an expert here, but having a huge respect for Bobcat (and less experience with other brands) skidsteers, slight secondhand on the toolcats, and now experience with an option I have to throw in...here's 2cents:
If turf damage is not an issue, you can't get more power for the footprint than a skidsteer.
For comfort, the toolcat sounds great and it does offer nice muti-function capability.
I just bought a PT, and think it fits your criteria well, but if either HP/footprint (I think the PT is a close second though) or Toolcat's cab are #1 on your list, those options become obvious.
Happy Shopping! /forums/images/graemlins/smile.gif
/ Toolcat for Spouse #3
Hi Gary,
Chad made some good comments that you want to consider. I'm not very familiar with the Power Trac, but I understand it is a very capable machine. You should also visit the Power Trac forum to investigate that possibility. That's the great thing about TBN, one-stop shopping! You'll be able to see all the options on this one great web site.
Since Chad has raised the subject of Power Trac units, it might be helpful to look at a <font color="blue">Thread</font> Brian (now a Toolcat owner) started comparing the Toolcat to the Power Trac 1850 when he was making his own purchasing decision.
My inclination is toward the Toolcat, of course, but it does have some merits in your situation. The Toolcat may well be a more comfortable choice for your wife is she's not comfortable with a large tractor. I myself didn't have any experience with tractors, so the Toolcat having more of a truck/car feel to it made that a more natural choice for me. While the Toolcat is not a tractor, it does have a very powerful engine and a front-end loader with a lot of lift capacity. With the addition of a hydraulic grapple, it will provide her with a very versatile tool to move all sorts of material. The Toolcat has the auxiliary hydraulics already built in and control on the joystick, so all you need to do is pick up your root grapple with its skid-steer connection, plug in two hoses and you're good to go. My need was for moving logs, but very large rocks are also candidates as well as vines and scrub brush. Of course, there are also all the other skid-steer attachments that you can buy or rent.
Another thing that I found to be a powerful incentive was that all the work is done in front of you, even the mowing and grading, no craning your neck looking back all the time to see what's going on, as you well know from using the 3PH on your John Deere. And the visibility is incredible! With the bucket flat on the ground, if you lean forward in your seat, you can actually see the edge of the bucket on the ground!
And if you have kids that may want to tag along, then the Toolcat offers an advantage that you can't find in a tractor with its passenger seat. The enclosed cab and HVAC will control temperature and dust if that's an issue for her.
The Toolcat is not a tractor, but it can do a lot of things that a tractor can do and some things that a tractor cannot.
/ Toolcat for Spouse #4
Haoleguy,
A Toolcat work machine would be great for you and your wife to "tool around" the 42 acres and also eagerly tackle lots of projects. And comfort and safety are addressed with its nice sturdy 2-seater cab w/HVAC, cupholders, familiar steering wheel/ brake pedal /movement pedal/ rear view mirror, comfortable joystick, sound muffling, seat belt/ shoulder harness, and BOTH full FOPS (falling object protection system) and ROPS systems.
I've felt a lot safer pulling out vines and brush with my root rake brush grapple while inside my Toolcat cab, instead of having to be exposed to falling or pulled objects smacking me! /forums/images/graemlins/blush.gif And you also don't have the dust knicking up in your face while mowing or moving dirt.
With Muhammad's announcement of HorsesByNet, I'd venture to say a Toolcat might even require less care and feeding and stabling over the years than if your wife caught the horse bug! /forums/images/graemlins/grin.gif And a Toolcat certainly takes on a lot more attachments than a team of horses! /forums/images/graemlins/cool.gif
/ Toolcat for Spouse #5
As a former CUT owner, current PowerTrac owner, and probable ToolCat owner, I'll chime in with a few comments.
When I got my NH TC-30 CUT I was quite pleased with those tasks that it made easier and/or possible. But as most of my property is very steep I was frustrated at what it could not do or could not go. I then discovered the PowerTrac 1845 (1/2 step down from the 1850 refered to above) and found it could do most everything the NH could do plus many it could not even dream of doing especially on 30 + degree terrain.
The PT is rather crude though. This is a plus with regard to maintanance, which with no dealer network, is a DIY task and the KISS philosophy becomes quite welcome. It is a very unique and capable machine (as are its smaller and larger kin), but may be of limited appeal to your wife. (The smaller PT-425 is quite popular however, check the PowerTrac forum above for many happy owners.)
The ToolCat is another unique and highly capable machine with significant European influence in its design. While not as extreme slope capable as the PTs, it should do as well in many catagories as a PT or CUT and better in many others. The dual seating with excellent cab, very good front lift and tool carier capability combined with rear bed capacity riveling a 1/2 ton PU is pretty much state-of-the-art for large property maintenence. The car-like feel and controls of the ToolCat will be very intuitive to get used to especialy compared to a SS.
Had the ToolCat been available when I got my PT I may have gotten it instead. As it is, I am seriously considering one now although I am spoiled with the steep terain capability of the PT and may just have to keep both at least for a while.
As a ToolCat is a rather large and expensive piece of equipment, I would suggest trying to arrange a several day or week long demo on your property to see how it would suit your needs and whether the wife would be comfortable with it.
In what is a "catagory of one" (at least in the US) there is nothing better than the ToolCat. For some it may be overkill however. A Utility vehicle such as the Kubota RUV, Polaris Ranger (I also have), or JD Gator may be all they really need and feel comfortable with.
Just my $0.02
Chad - The PT looks excellent for use in rolling terrain. During a recent visit to "Sideways" country I saw a NH crawler tractor impressively working a steep vineyard. Our property is relatively flat but I have considered the NH unit because of its narrow width and light feet for "future" vineyard work. I believe the Toolcat has the same narrowness and light feet. The cab and its features sets up well for working in cold winter weather, including snow removal, and possibly some night work. The only unknown for me at this time would be what sprayer choices I could pull behind the Toolcat. Thanks for your comments...
Rolando - How did you know that my neck is getting stiff from looking backwards on the JD? I need a rearview mirror. Your comments confirm what I have been thinking. Working in and around stone walls to extract the vines and invasive shrubs has been a bear to do for my wife. The nimbleness and strength of the Toolcat seems well suited for that work. I can only hope that the closest Bobcat dealer is as good and accommodating as my JD dealer...Thanks for the feedback.
Brian - Thanks for your comments now and with the previous threads you have started and contributed to. Care and feeding is an important aspect along with dealer support. Bobcat has essentially been a equipment dealer for contractors...how have you found their support for private landowners? How well does the cab AC and heating work in the temperature extremes?....Cheers.
/ Toolcat for Spouse #10
Haoleguy,
You can, but you may not need to pull a sprayer behind. Bobcat offers both 50-gallon and 75-gallon sprayer units for the Toolcat that sit on frame in the dump bed. See Bobcat Sprayer for Toolcat work machine. Sprayer includes 75-gallon tank, 14 gallon rinse tank, 2.5 gal hand/eye wash tank, mounted pump and 18-in. adjustable pattern wand with 50 ft. hose and reel for spot spraying. There's also an optional foldable 21-foot boom in three sections with 13 nozzles spaced 20 inches apart.
Also available is Plumbing Kit incl. harware and waterlines to plumb the front of the Toolcat machine for use with front-end attachments.
Rip - My mistake on using your message to respond to Brian. You hit the important point on the nailhead and that is getting one on my property for a demo by my spouse and myself. I know that the CT dealership for my area has a used one for sale which would mean to me they should be able to loan it out for 3-7 days. I have not had any dealings with the Bobcat dealer yet but I'm hoping for the best.....Thanks.
/ Toolcat for Spouse #12
I'll let my brethren to the north speak about heating, but here in central Florida the A/C had no trouble keeping up with 95°+ weather. And my understanding is that the C series has improved HVAC with larger ducts. The added sound deadening may also contribute to better insulation.
Rolando - Thank you for the link. Grape vineyard sprayers are a very different beast with a very high level of atomization and coverage. I like the idea of a pump switch inside the cab. Does one still need to wear protective mask & clothing inside the cab or is the driver hermetically sealed?...
/ Toolcat for Spouse #14
Gary,
You might try something that I did and found helpful. With the name of your dealer (or dealers) you plan to talk to, you could start a thread in the Construction Equipment forum (lots of Bobcats there) like "Info on 'dealer name' Bobcat" or "Bobcat Dealer Info for CT", and ask what kind of experience folks have had with their dealers. They may not own Toolcats, but people should be able to tell you how good the service and parts departments are and how they are to deal with.
/ Toolcat for Spouse #15
This is out of my league, but I would think that you would still need to wear protective gear. I'm sure that there's air recirculation going on, and while the filter will keep out the dust, I don't think it could keep the chemicals out.
/ Toolcat for Spouse #16
</font><font color="blue" class="small">( Brian - Thanks for your comments now and with the previous threads you have started and contributed to. Care and feeding is an important aspect along with dealer support. Bobcat has essentially been a equipment dealer for contractors...how have you found their support for private landowners? How well does the cab AC and heating work in the temperature extremes?....Cheers. )</font>
I'm sure Bobcat dealers will vary, but I have found mine very responsive to nontraditional customers, not despite their lack of consumer/hobby farmer focus, but possibly because they are used to satisfying demanding construction contractors. Contractors expect dealer responsiveness and bottom-line effectiveness to keep their jobs moving forward and their small or large construction businesses profitable. (Bobcat has to stay up with Caterpiller's level of service, which is high.)
For example, my dealer has multiple salesmen who divide up the dealer's territory by geography and serve as TRUE field representatives. These people spend most of their time on the road with customers and prospects, delivering parts and equipment orders and demos (right along with dedicated pick-up and drop-off employees out of rental dept.) right to the customer's job site whenever something is needed. They are truly servicing their accounts as well as selling. And the dealer's manager has been available to me and seems to support his field reps' customer service emphasis.
You're not expected to need to go to the shop in person. They actually respond to faxes, e-mail and cell phones. Parts and accessories I've ordered since initial deliveries have been delivered personally to me on a timely basis. (And not just 9-5, at least with my field rep.)
In addition to the half-dozen plus mechanics at each of dealer's two physical sites, my Bobcat dealer has several well-equiped mobile mechanics who go to the customer for repairs, esp. those repairs really needed right then. And, I secured a promise of free Toolcat service pick-up and delivery to/from the dealer's shop for the next three years, and not just for warranty work. I don't need a trailer!
When individual property owners contact Bobcat dealers, they're usually pretty serious buyers, so are hopefully treated with respect and attention. Toolcats are high-end compared to many CUTs and I think Bobcat wants to expand its customer base to that target group beyond construction and landscaping outfits. So I've been pleased SO FAR with my Bobcat dealer, even though I'm not in the construction business! /forums/images/graemlins/grin.gif
As for the AC, it worked just fine during some very hot days in Aug & Sept. It has adjustible output, three levels for the fan, etc.
/ Toolcat for Spouse #17
Been so busy almost forgot I was following this thread! /forums/images/graemlins/crazy.gif
Anyway, I'm not a true expert by any means but know just enough to pass my ag chemical cert. If you're shooting herbicides, the cab alone should be good protection; if recirculate is an option on the AC definately use that when spraying. Especially considering the fine atomization you're after, a little common sense with the wind and your travel direction will go a long way. As far as masks, I have my own opinion here: done wrong with pesticides is much worse than none at all: i.e. builiding up residues and potentially providing an even finer atomization to your lungs. For anything that really scares you SCUBA /forums/images/graemlins/wink.gif is about the only true clean air, but 1. if it scares you that bad don't use it /forums/images/graemlins/blush.gif and 2. your TC's cab should be a close second (with common sense on wind etc.) for desired effect anyway not absolute purity. /forums/images/graemlins/smile.gif
Also, anytime working with pesticides, wear clothing that can go right to the wash or garbage....with anything that may pentrate the skin (from pesticides to fiber glass) I like (actually hate) a cold shower immediately on dropping the clothes, then wipe off and enjoy a really long hot one.
Back to my reason for checking in...when do we get pictures? In action!? /forums/images/graemlins/cool.gif
Spiffy - Thanks for the perspectives. Interesting thought to check on cab recirculation. The right filter in the mask makes a big difference. However, you and I have different views on SCUBA air. Many years ago in Palau SCUBA tanks provided to me were converted fire extinguishers and it was clear that the fill compressor exhaust was in the vicinity of the intake. The result...dive headache. I hate to admit that this is not an uncommon occurence hence no guarantees even with SCUBA air. In the coming week I will be asking my local Bobcat dealer(s) for demo time. When that happens I will be carrying my dcamera. Thanks again....
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2014 CATERPILLAR 303.5ECR EXCAVATOR (A62129)
2014 CATERPILLAR...
Four (4) Firestone Combine 520/85R42 Tires (A63116)
Four (4) Firestone...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
2016 Kubota SVL 95-2S Skid Steer (A61166)
2016 Kubota SVL...
