Toolcat Fault 50-70
/ Toolcat Fault 50-70 #1
Dandow
2010 Bobcat Toolcat 5600
Hi,
New to this forum and have searched all over it for info related to an issue. Any help or direction would be greatly appreciated. Recently bought my first Toolcat and have a fault code giving me grief . It is a 2010 Toolcat 5600, s/n starting with A0W1. There is a fault code 50-70 which is "Rear Drive Reverse No Signal" and also "Auxiliary Hydraulics Base Error Off".
The unit drives fine most of the time, but have had a couple instances where it will not move forward or reverse. So I shut unit off, start again and it works fine, but code is constantly there.
Also sometimes the Rabbit/Turtle function does not light up or engage, while other times it works.
I have inspected shifter and wiring/harness. I am also assuming there is a sensor that ties into the drive somewhere to tell computer info that may be faulty but I have no idea which one or even where it is located.
Any idea or direction?
/ Toolcat Fault 50-70 #2
Not sure, the error codes are different on my unit...
