Toolcat "D" Series Info...
/ Toolcat "D" Series Info... #11
according to those numbers the lenght on the d will be 144.5 vs 147.5 for the c - three inches shorter??? I thought previously others thought it was going to be longer. shorter is better for me.
looks like the bed goes from 61x52 to 56x51 with same depth. 5 inches shorter and once inch more narrow.
width with smaller tires is 56 vs 60inch for the c ??? does that mean the cab is 4 inches more narrow???
i wouldn't want a more narrow cab if it meant less seat/shoulder/hip/leg room. the spine design would lend itself to a narrow body/cab at the expense of stability and room in the cab.
/ Toolcat "D" Series Info... #12
UFM82 said:
One big improvement with the D-series is a true hydrostatic drive system. That is just like the Bobcats meaning the machine will slow itself when you let off the drive pedal.....
On my 'A' Toolcat, if you let off of the drive pedal it will come to a stop in a hurry.
Speaking of coming to a stop in a hurry, I sure hope Bobcat either moves the Work Mode button or disables it when the Cruise Control is activated. After accidently pressing the Work Mode button instead of the Speed/Hours/RPM button (located side by side on the control panel) while traveling 18mph I can tell you it will stop real quick.
dsb
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
SKLP SK-HJ6 40' 6 Section Storage Shelves (A60463)
SKLP SK-HJ6 40' 6...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
2019 John Deere 6125R (A60462)
2019 John Deere...
