Toolcat and V417
/ Toolcat and V417
My wife was out mowing, I got a phone call :).
I used the V417 to pull the Toolcat out of the mud:
/ Toolcat and V417 #82
I bet she wishes you didn't carry that camera around with you all the time! :thumbsup:
/ Toolcat and V417
Yep, it is usually in the V417 :D.
We spent about an hour getting mud off of all the tires and inside the wheels on the left side :eek:.
/ Toolcat and V417
Filling in low part of terrace
This old aerial view shows the terraces that were put in to prevent erosion back when this was farm land. The blue arrow shows the area that I am working on north of the new horse barn. Water would accumulate here after a rain::
Put the 6' box blade on the V417 to move the top of the terrace into the low spot:
Getting more dirt to add to the low area:
Using the Toolcat, Tilt-Tach and Land Plane:
/ Toolcat and V417
Overdue update, pictures from 8-29-2020:
And satellite view:
/ Toolcat and V417 #86
In terms of ruggedness, reliability, and build quality, how does the Toolcat compare to the v417/v518 and the T770 track loader? Is the Toolcat any easier to work on (maintenance and minor repairs) than the other two types of Bobcat machines?
/ Toolcat and V417
I did use a T800 some, but have no experience with a T770, but the Toolcat is rugged enough to do what it is designed to do, very reliable and a high quality build with heavy duty parts.
About the same as the V518, for getting to the grease zerks.
/ Toolcat and V417 #88
Which one do you think will handle a skid steer type heavy duty brush cutter with mulching teeth for cutting cedars?
/ Toolcat and V417
If you can find a low flow cutter the V417 would be more versatile.
The Toolcat with the hi flow option would work well.
Our 7' brush hog is low flow 15-25 GPM, but we run it on hi flow and around 1700 RPM:
/ Toolcat and V417 #90
Why do you say that the V417 is the most versatile of the bunch?
/ Toolcat and V417
Because of the extending boom. This shows mowing across a silt filled creek.
This is what happens if you drive on silt:
/ Toolcat and V417
Removing another small cedar tree from the barb wire fence. Used tree limb loppers and a reciprocating saw to cut the the limbs on the east side:
Hooked the chain low on the trunk and pulled to the west, away from the T post:
The root ball moving caused the T post to raise up and lean to the west:
Used my cordless reciprocating saw to cut the trunk off of the root ball:
Used the landplane on the Toolcat from the east side, to push down on the dirt above the roots, straightening the T post:
pc030005-jpg.723434
Moved closer and pushed down again:
Drove around to the west side and pushed down on the stump:
The T post is straight, no more lean:
/ Toolcat and V417
Put the Monster Grapple on the Toolcat to pickup some previously pulled cedar trees.
At the first one:
The view from the seat:
Grapple down and closed:
Grapple and tree up:
View from the seat approaching the next one:
Grapple down and open:
Drove forward and curled down the grapple:
Grappled:
Took them to the brush pile:
Opened the grapple and curled it down:
/ Toolcat and V417
Just pickup up my new V417 yesterday. 5 hour drive to get it. Dealer claimed it was the last new tier 3 in USA. It was difficult to find a V417.
Have not seen anything from you in a while, need an update on your V417 please.
/ Toolcat and V417
The SSQA to 3 point adapter on the Toolcat:
On the V417:
Made a new dolly for it from an old shelf:
Drilled through the 3/4 inch plywood, used 1/4 inch bolts:
Here it is with the Omni Transformer 3 point hitch attached:
Picked them up with the crank up lift: See it here: Crank Up Counterbalanced Workbench / Lift
Set them down on the dolly:
Now I can roll it to the storage area:
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
