Toolcat 5610 F and 5610 G Series Pictures
   / Toolcat 5610 F and 5610 G Series Pictures
Look what I removed from the back of the Toolcat:
Before:
After:
Now when using the finish mower the lift arms won't hit the fence or buildings when turning.
   / Toolcat 5610 F and 5610 G Series Pictures #162
And easy to find the linkage when you need it again!
And easy to remove, no tools required. (y)
Mentioned the finish mower above, I realized that I didn't post pictures in this thread, so will do it now.
The 6' finish mower:
First use, with the FEL in float:
Later I moved the bottom linkage to the lower holes:
   / Toolcat 5610 F and 5610 G Series Pictures #165
That’s not a Bobcat mower, what brand is it?
Skid Steer Basics.
I bought it because of the articulated linkage to the SSQA. Use it in float and it works good on the uneven ground.
The headlight and turn signal blocked the view up close on the left:
Removed them and now I can see the back of the finish mower when cutting close to something in reverse:
Before:
After:
   / Toolcat 5610 F and 5610 G Series Pictures #168
Xfaxman notice this is a 3pt mower which when moving forward the apron of the mower is ag ground level, any issues it flattening the grass preventing the blades cutting? looks a solid unit I considered getting a 3pt mounting plate for my Kioti mower but ended up with the Bobcat finish mower instead
Don't know why you're calling it a 3pt mower? It was made for a skid steer or a Toolcat.
It is functionally the same as Bobcats mower:
The blades are slightly higher than the lower edge of the deck:
No issues even with tall grass and weeds.
   / Toolcat 5610 F and 5610 G Series Pictures #170
sorry saw the back linkage and figured it was adapted, should have looked closer
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
