Tool **** Friday.
   / Tool **** Friday. #171
Hear is one for you guys, the guy we bought the house from left it in the water shed. I was thinking it was some how used to sharpen a chainsaw. I was looking through a 1953 Stanley tools catalog and fond it In there. It's not a Stanley but it is all most like the one in the catalog.
He also left pliers
CWB.
Do the pliers lock? They look similar to hose clamping pliers for pinching off fluid lines for short periods.
   / Tool **** Friday. #172
The pliers don't lock but there is a groove that runs the hole length of the lower jaw. It would be about the right size for bailing wire. I looked up the manufacturer and it said that they made a lot of pliers for costume jobs.
Right off hand I don't remember the the manufacturer name. I'll look today when I go out to move the snow.
CWB.
   / Tool **** Friday. #173
CWB.
I think telephone company repair men were issued pliers like that back in the 60's & 70's.???
   / Tool **** Friday. #174
We had pliers like that for squishing UY and UR and UG splice connectors in the telecom industry. The jaws need to close in parallel so that the top "button" on the solder-less connectors comes down evenly into the bottom of the connector and the insulation displacement metal piece inside comes down evenly into the two wires you are trying to connect together and the "PIC" waterproofing materiel then squishes out the holes around the wires making the whole splice waterproof.
You can squish these connectors with regular pliers but the results are not nearly as good or consistent. There was also a "gun" that you preloaded with a "magazine" of 20 of these connectors and they fed into the gun "semi automatically" so that with each squeeze of the handles, it squished the connector and then when you opened the handle the spring pressure on the follower loaded another "round" into the "chamber" of the gun read for you next wire insertion and squeeze of the handle. This sped up the workflow as you didn't have to load a connector manually each time into manual pliers.
UY connector - - Yahoo Image Search Results
   / Tool **** Friday. #175
He also left pliers
CWB.
I too bought a pair of those pliers because they were strange.Put it on my what is it table.
   / Tool **** Friday. #176
Mine says Bernard on it. Apparently part of Sargent tools. Historical picture on this link off to the right in the middle.
Our History
My tool:
   / Tool **** Friday. #179
I looked they are the Bernard pliers. They come in handy ones and a while.
No guesses on the other tool. Here is a pic of the Stanley catalog. You have to make it bigger to see it. It's on the top right hand side and the description is at the bottom of the page. If I hadn't seen it in the catalog I would never have guessed what it is. I have used a few times and it works pretty good.
CWB.
   / Tool **** Friday. #180
I have all the part & pieces nuts & bolts Post & rails figured out for my backyard fence for muh dawgs. HF has what appears to be a pretty nice auger for an affordable price $179 and if I can use a 20% off coupon even more inviting. 4-ends 2-corners 4-line = 10-post holes total.
Ammco Brake Machine (A55758)
Ammco Brake...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
PALLET WITH 3/4TON DOLLY AND MISC TRUCK PARTS (A55745)
PALLET WITH 3/4TON...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
