Tool Cat UW50 Dead as a Door Nail!
   / Tool Cat UW50 Dead as a Door Nail! #21
Being that these things are heavy on electrics, I would disconnect the battery for 5 minutes and reconnect. Maybe it it just got confused and it needs to be reset.
   / Tool Cat UW50 Dead as a Door Nail! #22
If that doesn't work, many things have caused these things to be dead. Everything from bad grounds, bad ECU connection, etc.
Yup ..the old unplug and reset. Will give it a go.
   / Tool Cat UW50 Dead as a Door Nail! #24
I hope it works for you. I have a service manual but it is for a G series. I have tried to help some people with electrical issues but man, there is a lot of electronics in these things.
Does anybody know where the cab ground actually is? Checked a diagram but I still can't find it.
Posting this to close it out. My multimeter quest led me to the switch which I ultimately decided wasn't working via a jump wire. $500 for a new switch later, and she's purring again. Thanks for the kick in the pills, Bobcat!
Thanks for the help Ruffdog and crew!
   / Tool Cat UW50 Dead as a Door Nail! #27
what switch is worth 500 dollars? more curious what it is and which one
2019 TRAIL KING INDUSTRIES ADVANTAGE PLUS TRIAXLE RGN W/FLIP AXLE (A55745)
2019 TRAIL KING...
2012 International WorkStar 7400 T/A VacCon Combination Sewer Jetter Vacuum Truck (A55788)
2012 International...
2004 Winnebago Suncruiser IPG37B 38FT Class A Motorhome (A55758)
2004 Winnebago...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
White Metal Roof Panels (A55758)
White Metal Roof...
Peterbilt 377 Semi-Truck (A55302)
Peterbilt 377...
