Tool cat 5600 brakes seem like there in gaging
   / Tool cat 5600 brakes seem like there in gaging #1
&67
Bobcat 5600
I just purchase a 2013 toolcat 5600 and it bogs down and make a laboring noise in forward or reverse.Sounds like the brakes are engaging.Any idea what it could be?dealer is 60 miles away?
   / Tool cat 5600 brakes seem like there in gaging #2
That's not much to go on. Do you travel any distance before it bogs down? Does it stall completely or do you just push in the clutch to keep it running? Could you have your parking brake set? Sometimes I forget to release mine.
Thanks for the reply , no clutch,I put it in forward or reverse step on the petal and make a louder then normal (laboring) sound like brakes are engaging.I move forward/reverse around 20’ engine bogs down and it reduces speed.It started doing intermittently, now all the time.
2011 Kubota KX080-3 Midi Excavator (A53421)
2011 Kubota...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
