Tool Box
   / Tool Box #12
The only problem I had was condensation!! The box is so air tight,I had to drill a 1" hole,and insert a small louvered vent,problem solved.
   / Tool Box #13
Here's my answer to the tool box thing, it's on a L2800
The mounting system (no drilling or welding)
finished product (cost Zero $$$)
   / Tool Box #15
KCinBr, I like that one a lot. I've been looking at my L2800 wondering how to get a decent box on it. Where did you get the black bracket? Unless I can find something similar, it looks like welding and drilling for me (not that I mind either one).
Does it interfere with your view of the 3PH when backing up to an implement?
- Just Gary
   / Tool Box #16
JustGary, The mounting bracket is home-made from some scrap I had laying around. It's really very simple. The "U" piece that actually clamps around the ROPS is realy 2 "L" shaped peices, the cross piece can be made from almost anything. The tool box is............Craftsman of course. I think the key to mount that will hold the weight of all the stuff that ends up in a tool box is, to build it so it fits tight between the ROPS. I had to tap it in with a hammer.
And yes It does block the view a little but has not caused me any problems. My tractor is HST and when I hook up I'll just get real close( a couple of inches), put the tractor in low range, and from the right side standing on the ground I will use the HST pedal to move the tractor in to final position...Gotta watch yer feets.
Hope this helps...............KC
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2025 Poly Fuel Tank with Electric Pump (A55852)
2025 Poly Fuel...
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2018 Ford Explorer SUV (A56859)
2018 Ford Explorer...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
