Tool Box Mounting Pictures
   / Tool Box Mounting Pictures #21
Well done. Tell us about that rear loader bucket? Drop it, back into a pile, lift and tilt?
   / Tool Box Mounting Pictures #22
Here is how I did mine on the L4240, the B7800, and the BX2660. I made all three boxes also.
Can I see a front view of that chain holder? That is a genius idea. I assume there is a hole or two fro water to drain out each chain box? (sorry "chain box" in middle pic)
   / Tool Box Mounting Pictures #23
I'll take some tomorrow. You are talking about the L4240 right?
   / Tool Box Mounting Pictures #25
I took a picture, but not a lot to see. Couldn't get a picture of how it's mounted. The loader upright had a big hole in it not being used so I used it. I welded a 1/2" bolt near the bottom of a 3" X 5" thin wall tubing. Then welded a 3/8" bolt near the top of the tube. Had to drill a hole for the top bolt into the upright. The 2nd tube is 3" X 4" and just tacked welded on to the other.
Took a picture of the other side so you can see the one I put there. Also I wanted you to see my grabber I maded. I have about $550.00 to $600'00 in the grabber, bucket and the teeth. The teeth cost me $200.00 just by themself,so that well tell you what I have in the rest of it.
   / Tool Box Mounting Pictures #26
Thanks for the info and specs. Ive got a slightly older loader so I will have to check hole availability but to have something more durable then PVC and also get all these chains off my fender (I have to pull things out of the mud a lot :( ) would be a great improvement. Is that a single tooth grapple? I've been toying with tri-rear remotes and plumbing one to the front for a grapple but just have not gotten to it yet.
   / Tool Box Mounting Pictures #27
No, here is a better picture of it.
   / Tool Box Mounting Pictures #28
more ammo can mountings.
   / Tool Box Mounting Pictures #29
great ideas - ammo cans easy to get here... hmhmhmhm where is my can of Ferrari green paint????? like the chain holder also!!!!
   / Tool Box Mounting Pictures #30
If you look on Internet you can find some different size ammo cans. Shipping can be pricey. But you know they will outlast anything else.
2018 International TMA (A55973)
2018 International...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
15200 (A56857)
15200 (A56857)
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
