Tool box addition
/ Tool box addition #1
brianb88
Iuka, MS
Branson 5220R/FEL
I am curios if any of you Branson owners have added a small tool box to your tractor and if so where? I am thinking about mounting a plastic medium size ammo can (waterproof) on the right hand side on top of the fender and can do it without having to drill holes in the fender. There are a couple of holes already there from the factory that could be utilized. If any of you have added one what did you use and where did you put it? Any ideas?
/ Tool box addition #2
Fender sounds good.
Suggest you use a rubber or foam 'gasket' between the toolbox and fender to prevent abrasive damage.
Use large washers (auto style body washers) otherwise the plastic could tear out.
/ Tool box addition #3
This is one I attached to my 2400H. It can be removed easily by pulling on the u bolts at each end under the tool box.
/ Tool box addition #4
This is the box I added.
/ Tool box addition
Both of those pics look good. I tried the fender but it seems that isn't going to work with the box I have. I'm still thinking.
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
Kubota M7040 Tractor (A61166)
Kubota M7040...
2020 Toyota Tacoma Pickup Truck, VIN # 5TFRX5GN2LX180496 (A61165)
2020 Toyota Tacoma...
UNUSED KUBOTA 8 LUG WHEEL CENTER (A62130)
UNUSED KUBOTA 8...
UNUSED JOHN DEERE STRIP-TILL WHEEL ASSIST (A62131)
UNUSED JOHN DEERE...
